Old 03-20-2008, 08:55 PM   #1
Car: 07 STI OBP
Fav Mod: NUR SPEC R, 57maximum t/a,300 shot nitrous, dual carb, ITB,
Question Cobb AP response setting?
i just heard about a program about th AP that can inprove your accereration response. anyone using it or know about it?
Old 03-20-2008, 09:29 PM   #2
Car: OBP 07 STi
Fav Mod: Ring-Shaped Reinforcement Frame
Default Re: Cobb AP response setting?
You mean the stage 1 map? or something else?
Old 03-21-2008, 12:15 AM   #3
Car: Pearl Wht 07 STI
Fav Mod: SR56 turbo & Rays 18"
I was trying to find the answer to the question. I heard you could improve the throttle response by using Cobb Accessport, to eliminate the "drive by wire" lag. Does anyone know how?
STi Str8 Beast is offline   Reply With Quote
Old 03-21-2008, 04:20 AM   #4
Car: 2007 STI Ltd UGM#164
Fav Mod: ported/polished lug nuts
You buy the AP, and then flash your car to Stage 1. It helps the 07 tremendously.
Spend some time searching this site, and you'll find tons of info on this topic.
emanteno is offline   Reply With Quote
Old 03-21-2008, 04:22 AM   #5
^^^^^^ Yeah, that.
Old 03-21-2008, 09:02 AM   #6
Car: 07 STI OBP
so stage1 improves the throttle response? or do they have a different thing for the throttle response only? idk i just heard it from a friend and wanted to know.
Old 03-21-2008, 09:07 AM   #7
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
stage 1 will help but stage 2 is where it's at.
Hitman83 is offline   Reply With Quote
Old 03-21-2008, 09:08 AM   #8
Yes, just installing the Stage 1 map will make a huge difference. I can't personally comment on Stage 2 since I am not there yet, but from everything I have heard it is a beautiful thing.
Old 03-21-2008, 09:10 AM   #9
My STI was tuned professionally using the AP but it still has lag, I think I'm going to have to take it back and have them retune it then... I was reading cobbtuning.com and realized, like you said, that its integrated into the Stage maps that Cobb has online.. To bad I cant download just the revision for the lag. Thanks!!!! Drive safe
Old 03-21-2008, 09:41 AM   #10
any turbo car will have lag. It's the nature of the beast.
Old 03-21-2008, 09:43 AM   #11
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
Go back to your tuner and request that he copy in the European STI throttle mapping. I'm sure it's on the RomRaider board somewhere. But that supposedly has a much better curve.
Old 03-22-2008, 07:05 AM   #12
Thanks guys. I spoke to cobb and they updated my fuel map to result in better throttle response(smoother) and a knock correction was made to help the ECU learn a little better. I'll try it out and let you know the difference.
400+
Old 05-15-2008, 08:19 AM   #13
European STI mapping? I'll look into that.
