Old 03-15-2008, 01:25 PM   #1
Car: BLUE 04 STI
Fav Mod: element gt52
Default need help running lean
so i got the element gt52 on my car now but still have stock injectors, im gonna put pe850's in when i go get my protune, im gonna drive 2hrs away with stock injectors then put the 850s in when i get to the shop, but now the car is running really lean, at idle car shuts off the wide band reads between 16.5-18+, the car was running fine when i first put the gt52 its been 2 weeks and ive been driving it every day with no problems intil today
perfectshift is offline   Reply With Quote
Old 03-15-2008, 01:57 PM   #2
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
Default Re: need help running lean
your best bet is to call your tuner to get a base map for the 850's so you can install them now.
Hitman83 is offline   Reply With Quote
Old 03-16-2008, 11:06 AM   #3
Car: 04 sti
Fav Mod: enginuity tuned
did you install the turbo without any kind of tuning or supporting mods?
Old 03-18-2008, 03:28 PM   #4
Car: BLUE 04 STI
i have everthing but the injectors and a tune, i guess i should start with injectors plugs and a tune, i pulled a plug yesterday and it was a little white
Old 03-18-2008, 04:33 PM   #5
Car: 05 STI, 08 CBR1000RR
Fav Mod: None
You probably also need to check for any boost leaks or exhaust leaks before your tune. The car should run fine and drive around fine on the stock injectors, as long as you stay out of boost.
Old 03-19-2008, 02:07 AM   #6
Preturbo intake leak.
TheMadScientist is offline   Reply With Quote
