Old 03-10-2008, 03:58 PM   #1
Car: RBP 05 2.5RS Wagon
Fav Mod: Group N Lateral Link Bushings
Default Can a Water Temp Gauge Tell You Anything an Oil Temp Can't?
Yes, smartass, I realize an oil temp gauge won't tell me the temp of the water
Seriously though, I was going to put both water temp and oil temp into my car as a "when to start beating on it, when to stop" kind of display. Then I realized that it's only oil temp that I care about to track warmup.
So I guess my question boils down to is there a condition where the water temp is rising and I need to know that yet the engine oil temp isn't rising? Or is having a water temp and oil temp totally redundant?
On a totally different note, does anyone else think it's odd that the forum for gauges is the forum for tuning?
williaty is offline   Reply With Quote
Old 03-11-2008, 07:20 AM   #2
Default Re: Can a Water Temp Gauge Tell You Anything an Oil Temp Can't?
well if i could only pick one i would go with the water temp gauge....
It makes sense for the gauge and tunning to be together b/c they go hand in hand....
Bryants07STI is offline   Reply With Quote
Old 03-11-2008, 07:38 AM   #3
Car: '06 steel grey, son.
Fav Mod: learning how to drive stock first
as for when to start 'beating on it'... oil is probably better indicator. as for when to 'stop beating on it'.... they will both tell you different things. your water could be too hot while oil fine and vice versa..
btw, powell has 2 'l's.... how old are you, do you know jordan?
edit:
nope. gauges are a tuning tool... where else would they go?
nonissan is offline   Reply With Quote
Old 03-11-2008, 07:40 AM   #4
Fav Mod: Synapse FMIC
If I could only pick one I'd go with Oil Temp, especially since you already have a somewhat accurate water temp gauge on the dash.
jays05 is online now   Reply With Quote
Old 03-11-2008, 07:41 AM   #5
STI Guru
Fav Mod: grip.
water temp > oil temp.
that being said.
i have both.
Old 03-11-2008, 07:48 AM   #6
not sure how accurate our h2o gauges are...
are our stock coolant gauges ok?
Old 03-11-2008, 10:00 AM   #7
Fixed, 27, no.
Old 03-11-2008, 01:24 PM   #8
Moderator & ECU Tech
Fav Mod: mo boostaz
Without a doubt - oil temperature. Why? You have no means AT ALL to measure oil temperature. So - put one in the car. Your car comes with a gauge on the dash that is a very good indicator as to the coolant temps. Furthermore, the ECU reports coolant temp. Thus, you can use the gauge on your dash and logging to get coolant temp. For oil temp you have nothing.
t
