Old 02-25-2008, 06:28 PM   #1
Car: BLUE 04 STI
Fav Mod: element gt52
Default gremlins in car
i tried hooking up my launch control through my utec but didnt read the instructions all the way through, i never disconnected the cruise control switch, now when i drive hard i lose my tune, all my gauges go crazy the speedo stops working security light flashes all the time and cant bring it past 4500rpms without backfiring . i tried putting a new ecu in today with out the utec hooked up, everything is the same.
has anybody had this problem before????
perfectshift is offline   Reply With Quote
Old 02-25-2008, 06:34 PM   #2
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
Default Re: gremlins in car
oh man, this is out of my league.
good luck
Old 02-25-2008, 10:11 PM   #3
Fav Mod: Tires and Brakes!
regards to your PM
Hmm I probably wont be of any help. I have never dealt with utec before
What do you mean you lose your tune? If you hooked up wires yourself I would just double double check every connection to make sure you did not cross anything. Does your car work fine with launch control , not on?
gosu is offline   Reply With Quote
Old 02-26-2008, 04:54 AM   #4
Car: BLUE 04 STI
i have to re load my tune when everything goes crazy, then it goes back to normal. i unhooked the wires and everything is the same. i think i fried something but cant figure it out i traced everything back and nothing seems burnt up. do you know what computer controls the security system or all the gauges.
Old 02-26-2008, 09:52 AM   #5
3. Do not, under any circumstances, tap the UTEC clutch switch wires into the clutch
switch with the stock clutch wires still connected. Trust us, this will result in all sorts
of electrical gremlins that may well ensure your car never runs correctly again. If
you fail to heed this warning, you may as well douse your car in race gas and light it
off, because it’s as good as dead. You think we are kidding? TurboXS has no sense of humour. You have been warned.
Right from page 61 of the Utec manual. Good luck.
TheMadScientist is offline   Reply With Quote
