Old 02-23-2008, 10:53 AM   #1
Car: White 07 WRX STI
Fav Mod: Driver weight reduction
Default 07 STI Cobb OTS stage 2 (1.03) data log
Did some data log using enginuity (romraider). Mainly looking for knock events and my boost pressure. I did a brief 4th gear pull, feed back knock correction stays 0 all the time except 1 log event where it drops to -1.4. Fine learning knock correction goes to -2.8 at a later log event (otherwise 0). May be that's because I ease off the throttle briefly (chickened a bit, on public road lol) Should I be concerned ?
Only engine mod is a Cobb downpipe. Running 91 octane cali gas stage 2 map.
Thanks !
Code:
Acc Ped. Ang.  Engine Load    Engine Speed   FBKC           IAM            Knock Corr Adv Man. Rel Pres.
61.18          0.2            2793           0              1              0              -6.82
88.63          0.78           2795           0              1              0              1.6
95.29          1.49           2918           0              1              3.87           5.8
100            1.92           3026           0              1              4.22           11.32
100            2.47           3167           0              1              4.22           15.09
100            2.78           3336           0              1              3.35           15.53
100            2.76           3502           0              1              3.8            15.53
100            2.76           3664           0              1              4.2            15.53
100            2.8            3889           0              1              3.74           15.67
100            2.74           4028           0              1              3.25           15.53
100            2.8            4164           0              1              2.93           15.67
100            2.89           4339           0              1              2.78           15.82
100            2.85           4531           0              1              2.85           15.67
100            2.8            4662           0              1              3.28           15.67
100            2.84           4820           0              1              3.56           15.67
100            2.85           4993           0              1              3.4            16.11
100            2.91           5126           0              1              3.01           15.96
100            2.95           5287           0              1              2.88           15.96
100            2.92           5449           0              1              2.86           15.82
100            2.86           5572           0              1              2.85           15.67
100            2.82           5662           0              1              2.67           15.53
100            2.76           5791           0              1              2.64           15.53
76.08          2.73           5930           0              1              2.59           15.38
33.33          2.67           6090           0              1              2.91           -0.87
100            0.98           6124           0              1              0              9.58
100            2.31           6224           -1.4           1              1.59           14.95
100            2.58           6311           0              1              3.32           14.95
100            2.56           6370           0              1              3.29           15.09
0              2.54           6442           0              1              3.5            2.03
0              1.1            6454           0              1              0              -11.32
0              0.17           6440           0              1              0              -11.32
0              0.17           6209           0              1              0              -11.32
0              0.18           5879           0              1              0              -11.46
0              0.18           5604           0              1              0              -11.46
0              0.19           5318           0              1              0              -11.61
0              0.2            5036           0              1              0              -11.46
fast08 is offline   Reply With Quote
Old 02-23-2008, 01:26 PM   #2
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
Default Re: 07 STI Cobb OTS stage 2 (1.03) data log
I think you should log some more.... At least it is not knocking like crazy!
BBBsti LTD is offline   Reply With Quote
Old 02-23-2008, 04:03 PM   #3
i logged quite a bit actually this is one of the few pulls that caught my attention i thought cobb maps does not knock am i reading this wrong?
Old 02-23-2008, 04:38 PM   #4
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
Thats no guarantee every car runs different. They try their hardest though to get it to work with all cars. When I built my exhaust even with a catalytic converter in it mine hit boost cut (19.25psi) when target boost was 17.5 so I just bit the bullet and went and had it pro tuned.
CenCali07STI is offline   Reply With Quote
Old 02-23-2008, 07:42 PM   #5
Car: 07 STi, Ducati 1098
Im not an expert, but do use open source, and -1.4 once, doesnt really mean anything. Your always going to get a slight amount of knock, and according to that log, and you saying its the worst, it seems your doing ok. It is under high load high RPM, so you dont want anything really higher than that, but it looks ok. I am suprised your not boosting very high..what is target boost on that map??
Skter505 is offline   Reply With Quote
Old 02-23-2008, 09:24 PM   #6
The logged target boost around the -ve FBKC is 17.xx . I'm a bit below that. Thanks.
