Old 02-21-2008, 08:06 PM   #1
Fav Mod: getadomtune
IWSTI Addict since: Dec 2007
Send a message via AIM to johnsm Send a message via MSN to johnsm
Default Need help with DOM3 tune.
We were tuning 07 STI with Blouch DOM3
Following mods.
Blouch DOM3 2.4
920cc moded stock injectors
Tial 44mm EWG
Grimmick Inlet
APS 70mm
APS 525 FMIC
Walbo pump
NGK cold plugs
Snowperformane Meth injection
Perrin BOV
Stock TVG
johnsm is offline   Reply With Quote
Old 02-21-2008, 08:46 PM   #2
aka: jnprn2003
Fav Mod: EFI Logics tunage
IWSTI Addict since: Feb 2007
Trader Rating: (13)
Default Re: Need help with DOM3 tune.
Who's tuning it? Dyno? Octane fuel? No leaks? I doubt the stock inlet is that restrictive...at 23psi you should be doing more...much more
RONIN is offline   Reply With Quote
Old 02-21-2008, 09:13 PM   #3
we are thinking its injectors, will be swapping them this weekends.
Mustang dyno, 92 oct with meth, very small uppipe leak.
Old 02-21-2008, 09:15 PM   #4
IWSTI Addict since: Apr 2005
1) Who's tuning it? I'm guessing open source? Otherwise they'd know if the MAF voltage was pegged.
2) I'd suggest getting a big MAF intake like the APS 70mm. My GT52 turbo which is slightly smaller than the Dom3 maxes out a 65mm intake.
3) Get a better turbo inlet. I have the APS hard pipe and you definitely can't go wrong as with most APS products. The Perrin or Samco or whatever silicone hoses are a good
Everything else looks good.
Old 02-22-2008, 09:46 AM   #5
Car: 05 Legacy GT
IWSTI Addict since: Apr 2007
And it wont make more then 315whp at 23PSI. We thought it might be a air restriction in the inlet.
What was the limiting factor? For starters, what were your AFR, IDC, & total timing at peak power? And at peak torque?
How much boost were you shooting for?
NSFW is online now   Reply With Quote
Old 02-23-2008, 09:45 PM   #6
every thing fixed, it was gay ass injectors from nasioc!!!!!
Old 02-24-2008, 11:24 AM   #7
Car: 06 Subaru WRX STI
IWSTI Addict since: Sep 2006
For an 07 you don't need a big maf. I agree with the Inlet upgrade. I have a sz49 with similar mods, that I open source tuned 445Hp/485TQ at 25 Psi.. the thread is on NASIOC.
The OS platform, is a very good tuning tool. After hearing the full story(this week), I don't agree with how they developed it, but I have countless hours tuning with it none the less. I have a TXS intake and my AFRS are spot on. Remember the MAF table is not an absolute...it is merely a ratio. Therefore the g/s value is not what you are actually flowing. I would agree, however, with a competent tuner..properly scaled, the 70mm is a very nice intake.
I realize you had an injector issue, but I would make sure you have no engine issues from improper fueling. Any questions, I would be happy to help you out. Good luck with the car, I am def. interested what your curve looke like.
John
Tuner, Precision Tuning
IWSTI screen name-John@Precision
I did not realize I was logged in under my girfriends screen name...OOPS. SORRY.
Blackongold06 is offline   Reply With Quote
Old 02-24-2008, 01:04 PM   #8
Moderator & ECU Tech
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
I disagree with using a stock-type 65mm intake on setups where you are going to peg it. I just firmly believe in not doing this. A 70mm MAF (like the APS or Cobb unit) will give you around 400whp of resolution. Once you get over 400whp you are going to risk pegging the 70mm MAF. At this whp point, you are going to need a 3"+ MAF. Please don't give up MAF resolution by hacking the fuel tables. This is a hack and, IMHO, it is an improper way to tune.
t
Old 02-24-2008, 01:23 PM   #9
Would you guys still recommend me to upgrade my stock inlet?
What happen with my car is one injector was running very rich and other one very lean. Right now i got some injectors from Kito @ KAS Seattle.
Runs very good!
tuned by GetaDomTuned!
Old 02-24-2008, 03:06 PM   #10
Car: 04 Black STI
IWSTI Addict since: Dec 2005
Send a message via AIM to reid-o Send a message via Yahoo to reid-o
Runs very good!
This was confirmed?
That's not a good thing that you were running 23psi with uneven fuel flow characteristics.
Were you getting a lot of ignition retard?
Ask your tuner to post a datalog, so we can either smile or gasp.
Id honestly like to see what kind of ignition timing you pull with that particular turbine housing and compressor.
reid-o is offline   Reply With Quote
Old 02-26-2008, 11:14 AM   #11
Car: 07 Ltd. STG4 445/485
IWSTI Addict since: Jan 2008
Send a message via AIM to John@Precision
So are you implying that I must have values of either 8.5 or 13.5 in the fuel tables to achieve a desired...say 11.0 AFR? That is merely not the case. I would agree if you are living at, or after, 4.85V you should upgrade to a larger MAF in order to maintain resolution. I would not, however turn a customer away because he/she does not have a larger MAF. I will keep an eye on voltage though, and explain to the customer the potential benefits of upgrading. As I stated, or understated ,I do not encourage anyone to 'hack' a fuel table and the 70mm is a very nice option. As a tuner... or former GM engineer .. we should encourage the proper equipment for the job.
t
John@Precision is offline   Reply With Quote
Old 02-26-2008, 06:20 PM   #12
The turbo runs strong!
I was driving in 1st gear at 5.000 rpm give if full gas in my clutch started to slip at 6.000 rpm. lol
i cant tell where it fully spools because rpm's just jump up with it starts, i see good spool at 4000 rpm.
not too laggy.
Old 02-26-2008, 07:01 PM   #13
Fav Mod: ProTune
IWSTI Addict since: May 2006
Send a message via AIM to kigger012
how's the fitments?? was it hard 2 fit?? b/c i was going 2 get this but some ppl say that u have 2 delete the tgv, and it doesn't fit that well....
can u post some pics??? thanks...
kigger012 is offline   Reply With Quote
Old 02-27-2008, 03:50 AM   #14
Fav Mod: mo boostaz
Originally Posted by John@Precision View Post
... we should encourage the proper equipment for the job.
This is my entire point.
t
Old 02-28-2008, 09:47 AM   #15
Fitment was easy! You just have to put something behind the oil return line (i put my knife with big handle there, that helps.
first i put in the inlet on the turbo secure it, then get it in the return line.
Parts!
