Old 05-02-2008, 09:10 AM   #31
Default Re: Need help with DOM3 tune.
Originally Posted by johnsm View Post
Well I guess do to the problems i had with leaks and restrictions he had to make a retarded map for me.
Tomorrow I will post new logs and new map. Will see!
btw. tuner is a very proffessional and tuned for many years.
We'll see how he stacks up
Tgui is offline   Reply With Quote
Old 05-04-2008, 10:52 AM   #32
Car: STI UGM LTD
Send a message via AIM to johnsm Send a message via MSN to johnsm
Car made 20 more WHP after tune.
So we at 340 mark, and like 345 -335 torq range.
Still this numbers make me cry, when blouch DOM 3.0R makes 390 on pump gas. Ill post the map here when i get chance,
This was a Mustang dyno
Tuner thinks its 2.4 inlet with 7cm restriction and stock TVG's.
johnsm is offline   Reply With Quote
Old 05-04-2008, 12:15 PM   #33
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
Something is way off period.. 340/335 is 20G with TGV's 2.4 inlet, 7cm etc.. Your tuner is flat out not tuning you correctly and I would be worried if I was you. The tuner telling you that he THINKS its a 2.4 inlet or TGV... He should know exactly what the problem is.. How much money have you dished out on tunes??
The things he said are the problem are not, yeah the TGV and 7cm restrict you to a certain point but not to see the very low number your seeing and the 2.4 inlet has nothing to do with it.. I can only tell you to find a new tuner ASAP and I would be getting my money back from this so called tuner..
Old 05-04-2008, 06:38 PM   #34
Car: STI UGM LTD
This morning i took logs, in 3d gear after 6k rpm engine feels like its chocking and it drops power (to me sounds like engine about to blow up)
Here are 2 3d gear pulls , http://ofps.net/pics/log5.zip
Thank you guys for helping me.
I spend 1700 bucks tottal on 5 tunes !
Map http://ofps.net/pics/5thMap.zip
Old 05-04-2008, 06:45 PM   #35
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
Trader Rating: (12)
Send a message via AIM to MacSTi
Are you going to finally answer who is tuning your car?
MacSTi is offline   Reply With Quote
Old 05-04-2008, 07:05 PM   #36
Moderator & ECU Tech
Fav Mod: mo boostaz
So professional and experienced that he utilized a stock-ish MAF curve for a 70mm MAF .
t
Old 05-04-2008, 07:07 PM   #37
Fav Mod: mo boostaz
Wow. Unbelievable. Totally unbelievable. Find a new tuner who will give you real advice without taking your money ... and then taking your money ... and then taking your money ... and then taking your money.
t
Old 05-04-2008, 07:12 PM   #38
Fav Mod: mo boostaz
Well I guess do to the problems i had with leaks and restrictions he had to make a retarded map for me. Tomorrow I will post new logs and new map. Will see!
I just checked your latest map. You still have not been tuned properly for the 70mm MAF and your big injectors. Looks like the 'retarded' map wasn't due to the 'leaks and restrictions'.
GLHF.
t
Old 05-04-2008, 07:54 PM   #39
Car: 06 STI / STG 4
First off wether its done or not its not the proper way to tune. The fact that he continued to take your money and not correct it is CRAZY.. I would be going nuts if I spent 1700 bucks and that was my car.. I am not tryin to be a deek but.. Listen dude PM John@Precision he is my tuner here in NJ he is a great guy willing to help anybody, and he is a great tuner super informative send him your logs etc just so he could tell you.. All I can say is I wouldnt feel safe with that tune at all.. Good luck dude
Old 05-04-2008, 07:55 PM   #40
My initial points still stand, especially the lack of scaling to over 3 g/rev in the appropriate maps. The fuel table sucks, maf blows, and everything else blows and or sucks (your choice).
This isn't a knock against you, but you got take for $1700. To save money and your car you might have the best bet learning to do things yourself. Head over to romraider website to get some help and learn
Just think, $1700 could have gone to a rotated setup :P
Sorry that you had all these troubles.
Old 05-04-2008, 07:56 PM   #41
Ohh, and BTW, who was this tuner?
Old 05-04-2008, 08:37 PM   #42
Car: 05 Legacy GT
He already told us who tuned it:
What happen with my car is one injector was running very rich and other one very lean. Right now i got some injectors from Kito @ KAS Seattle.
Runs very good!
tuned by GetaDomTuned!
NSFW is offline   Reply With Quote
Old 05-04-2008, 08:41 PM   #43
Car: STI UGM LTD
i ask tuner to post in here and maybe he can explain more.
Old 05-04-2008, 09:08 PM   #44
Ahhh, missed that. ... And d'oh. Hope we can all chat civil like, from what I remember, he sounded like a decent guy.
Old 05-04-2008, 09:15 PM   #45
Car: 05 Legacy GT
I agree.
