Old 04-20-2008, 01:24 AM   #16
Car: STI UGM LTD
Send a message via AIM to johnsm Send a message via MSN to johnsm
Default Re: Need help with DOM3 tune.
Update.
Fixed a big IC leak 2 weeks ago.
Installed Grimick inlet.
Got a perrin BOV
Today at dyno only made 320 again!!!
My tuner says car won’t make any more power, he adds fuel and boost and we get less hp. also we tryed to adjust everything with out meth first car would only make 280
this was 4th dyno already. Each dyno is 350 bucks. i have no idea wtf can be wrong.
my map http://ofps.net/pics/map.zip
any ideas?
johnsm is offline   Reply With Quote
Old 05-01-2008, 05:35 PM   #17
Originally Posted by johnsm View Post
Update.
Got a perrin BOV
any ideas?
Your tuner blows.
1) Your fuel maps are shiite. Either hes trying to make them bad on purpose, or covering up some MAF scaling/injector scaling issues.
2) Your WGDC map is crap. You hit about 38% WGDC. Unless you have a MBC I missed, you might need to up that.. a BUNCH.
3) Your Timing Advance maps are absolute crap. Your max knock correction is 2 degrees. Thats not enough timing pulled to save your motor when knocking. You should have about 10+ degrees in this map in high load areas.
4) WTF, seriously, your tuner didn't even scale your maps past 2.5 g/rev?? I hit 3.4 with the stock vf39. All maps with a g/rev axis need to be scaled. Jebus save me...
Allot of this depends on how the maf and injectors were scaled in concert. From the evidence at hand, you need to ask for money back from your tuner. Good god....
BTW, post up some logs, like 3rd gear logs from 2-7k.
log:
RPM
Total Timing
Knock Correction
IAM
Wideband AFR
g/rev
psi corrected
accelerator pedal%
Tgui is offline   Reply With Quote
Old 05-01-2008, 07:43 PM   #18
Car: STI UGM LTD
Thanks for info,
turns out looks like it was a IC 90 deree elbow was to far on the inlet of the turbo, it was making a restriction.
This saturday going again to KITO @ Seattle.
Originally Posted by Tgui View Post
Your tuner blows.
log:
RPM
Total Timing
Knock Correction
IAM
Wideband AFR
g/rev
psi corrected
accelerator pedal%
Old 05-01-2008, 08:02 PM   #19
Thanks for info,
If this is the same place as before, you REALLY need to watch out. I'm serious, the tune you posted is down right dangerous.
Old 05-01-2008, 10:39 PM   #20
Car: 05 Legacy GT
OP said he had 920cc injectors, and the map is set for for 650cc.
So the AFRs show in the fuel maps are much leaner than the car was actually running.
Why not just set the injector scaling at 920, I wonder?
NSFW is offline   Reply With Quote
Old 05-02-2008, 03:18 AM   #21
Moderator & ECU Tech
Fav Mod: mo boostaz
BTW - your MAF table isn't even scaled for a 70mm MAF (lol). Good luck with that.
t
WolfPlayer is online now   Reply With Quote
Old 05-02-2008, 04:11 AM   #22
Fav Mod: when it's not blown up
I looked at the map and I don't like it either, but I have seen far worse from even more reputable tuners.
Wolf regarding the dynamic advance maps, keep in mind this is an 07 and they don't work the same as pre-07.
Old 05-02-2008, 05:55 AM   #23
Good point. My post was somewhat of a knee jerk response. Though I'd still like to see more than 2degrees, but then again, I'm not an 07-08 expert by any means.
Old 05-02-2008, 06:00 AM   #24
Looks like a maf table/ fuel table bandaid instead of proper scaling and latency setup.
Old 05-02-2008, 06:02 AM   #25
^ so many tuners do that, I saw the same thing in a PDX tune as well.
Old 05-02-2008, 07:42 AM   #26
Fav Mod: mo boostaz
I didn't say anything about DA
t
Old 05-02-2008, 07:42 AM   #27
Fav Mod: mo boostaz
WORD! I hate it when they do this. It is retarded. The customer is paying for a tune. Do it correctly!
t
Old 05-02-2008, 07:50 AM   #28
Lol that was tgui, I need to stop posting before the 3rd coffee.
Old 05-02-2008, 08:09 AM   #29
I figured as much.
Old 05-02-2008, 08:56 AM   #30
Car: STI UGM LTD
Well I guess do to the problems i had with leaks and restrictions he had to make a retarded map for me.
Tomorrow I will post new logs and new map. Will see!
btw. tuner is a very proffessional and tuned for many years.
