Old 02-19-2008, 07:34 AM   #1
Car: 2005 STI
Fav Mod: Methanol
Default Can I get a difinitive answer on EGT probe location?
My inclination is to ask my tuner, and do what he says. He says mount it in the DP. I have always heard 6" from the exhaust port of #4, which I believe is drivers side, closest to firewall.
My searching shows many people saying that the DP is a terrible place to put it. And the reasons make sense to me. Theres too much temp change from the exhaust port till after the turbo.
Tuner says they put it in the DP due to varying qualities of EGT probes, and fear that it will break off/damage the turbo.
So once and for all, DP for safety? or header for accuracy?
Gauge is STRI as well.
Also, im getting gruppe-s coated headers, stri directions say to drill and tap. If I weld in a bung, it looks like the probe wouldnt reach in far enough. Drill and tap work okay?
THANKS
xrocket21 is offline   Reply With Quote
Old 02-19-2008, 07:41 AM   #2
STI POWWA
Car: 06 Subaru WRX STI
Fav Mod: My 20g
Default Re: Can I get a difinitive answer on EGT probe location?
Do it in the headers. How often do probes brake off? What is going to brake it. Get a Carbing metal undertray and then nothing can harm it.
diabloadsit is offline   Reply With Quote
Old 02-19-2008, 07:41 AM   #3
STI POWWA
Fav Mod: My 20g
Plus your gauge will work like it is supposed to.
Old 02-19-2008, 10:31 AM   #4
Car: 2007 STi LTD
Fav Mod: Stg. 2 with Knocklite
Put it in the manifold 6" or closer in cyl 4.
BBBsti LTD is offline   Reply With Quote
Old 02-19-2008, 12:21 PM   #5
Car: WR Blue 05 Sti
I like to know some more info on this subject as well. My Gruppe-S jet hot coated header does not have a egt bung but I have a larger up pipe with an egr bung I will install when I upgrade my turbo. I've heard that this location is not ideal but what other options do I have besides grinding the $175 coating off enough to weld a bung in the header leaving an unprotected area in the coating.
helifreak is offline   Reply With Quote
Old 02-19-2008, 12:59 PM   #6
STI POWWA
Fav Mod: My 20g
Sorry you have no more options if you want it to work right.
Old 02-19-2008, 05:55 PM   #7
Car: WR Blue 05 Sti
How important is a egt gauge anyway why not use an a/f instead? I would think an a/f would be a better indicator.
Old 02-19-2008, 05:57 PM   #8
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
Trader Rating: (12)
Send a message via AIM to MacSTi
EGT is vitally important because this will not translate into A/F ratios and a High EGT could be bad and a early clue to running too lean.
MacSTi is offline   Reply With Quote
Old 02-19-2008, 07:39 PM   #9
Fav Mod: Teh Mature Diffuser Will Return!
Send a message via AIM to KiR DieseL
In the HEADER
/Thread
Mine is also placed there as well.
KiR DieseL is offline   Reply With Quote
Old 02-21-2008, 05:40 AM   #10
Banned
Car: 07
Up pipe
Reason I say this is yea 4 does run the hottest BUT you are only measuring the egt from 4. If you have a fouled plug adn say 3 is running really lean your not going to know. I say measure the egt as a whole not just one cyl cause then you might be asking for trouble.
White Devil is offline   Reply With Quote
Old 02-21-2008, 06:09 AM   #11
Car: 2005 STI
Fav Mod: Methanol
Which one is cyl 4?
Old 02-21-2008, 06:17 AM   #12
Banned
Car: 07
4 is driver side closest to the firewall
from the driver seat
2 1
4 3
Old 02-21-2008, 06:59 AM   #13
Car: WR Blue 05 Sti
Why is it that 4 runs the hottest?
Old 02-21-2008, 07:26 AM   #14
Banned
Car: 07
That i couldn't give you a answer to and be comfortable with teh answer I give you. I can find out though
Old 02-21-2008, 09:06 AM   #15
Car: WR Blue 05 Sti
Maybe it has do do with the fuel rail issue in which one cylinder runs a bit leaner than the others under hard acceleration. I had read about this subject on here and some were saying that it has to do with the design of the stock fuel rails does not evenly distribute the fuel to all cylinders.
