Old 02-09-2008, 10:27 PM   #1
Default Only boosting at 11 PSI with ECUtek tune
This has happened to me twice already where my car would all of a sudden only boost at 11 PSI. When I reset the ECU it goes back to normal.
I have a Helix catted DP with custom ECUtek tune. Does anyone know what might cause this? My tuner has been MIA for over a year so I can't ask him.
It happened today at my track event. When I reset the ECU between sessions it would boost at 16 PSI. This is better than 11 PSI but still lower than the 18.5 I would normally get.
na-STi is offline   Reply With Quote
Old 02-10-2008, 04:10 PM   #2
Car: 07 SWP STI
Fav Mod: Tim Bailey Protune
Default Re: Only boosting at 11 PSI with ECUtek tune
you might want to check your vacumm lines. sounds like a leak
ItalianStallion is offline   Reply With Quote
Old 02-10-2008, 07:13 PM   #3
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
Sounds like stock wastegate spring boost. check all your vacuum line connections in the boost soleniod area and coming off the turbo anywhere else they run too. you might even have a crack in one of them if they are not disconnected.
CenCali07STI is offline   Reply With Quote
Old 02-10-2008, 09:06 PM   #4
Car: 06 Subaru WRX STI
Fav Mod: Headlight Adjustment
Send a message via ICQ to MasterColin Send a message via AIM to MasterColin
If it is a leak would it change as he resets? I would think it would stay down.
MasterColin is offline   Reply With Quote
Old 02-10-2008, 11:03 PM   #5
That's what I was thinking. It happens when I stay in third gear near redline for a few seconds. Such as going through a series of medium speed turns on a road course all in third gear. But it seems to be totally random since it has only happened me twice, once at the track and once on the street. Is the ECU sensing something bad and cutting boost?
Old 02-10-2008, 11:36 PM   #6
The Stig II
Fav Mod: EFI Logics tune
Vacc leak...it happened to me an I ran on WG boost for the ride until I got it fixed.
jnprn2003 is offline   Reply With Quote
Old 02-11-2008, 12:51 PM   #7
Does anyone have a diagram of all the hoses I should check or a link to another thread that has a diagram? Do I need to buy better hoses?
