Old 02-08-2008, 12:10 PM   #1
Car: 06 STI OBP
Fav Mod: Stage 2
Default launch controll help
I am following cobbs directions perfectly but I can't seem to be able to set up the two step or flat foot . Any tips? I have been trying for like an hour.
Lostlife656 is offline   Reply With Quote
Old 02-08-2008, 12:29 PM   #2
Fav Mod: Ring-Shaped Reinforcement Frame
Default Re: launch controll help
Are you sure you have a lc enabled map loaded? It should work without any setting up if it is loaded. IIRC it has 4500 rpm as the default when you load the map.
Old 02-08-2008, 01:53 PM   #3
Car: 06 STI OBP
Fav Mod: Stage 2
I want to raise them both a bit. I have the map loaded to reflash. The two step works but I want it a bit higher
