Old 01-23-2008, 12:59 PM   #16
Car: 04 JBP STi
Fav Mod: Me Driving The Car
IWSTI Addict since: Apr 2007
Default Re: * *having problems with my 04* *
if it is the clutch.. what after market clutch can i go for?? my goal for my car is get around 400whp.. so i want something that can be reliable at that power...
xAxAx is offline   Reply With Quote
Old 01-23-2008, 01:00 PM   #17
Car: 08 STi, SSM
IWSTI Addict since: Dec 2005
find a wide open area where you won't hit anything. put the car in neutral and stand on your brakes, put the car in fifth or sixth gear and slowly let the clutch out. If you don't kill the car, your clutch is toast. It sounds like it's done. Also check your MAF o-ring, I'm betting you cut it when you installed the K&N.
Old 01-23-2008, 01:03 PM   #18
NIИja
IWSTI Addict since: Jan 2006
One more thing, which way is your MAF sensor put back in?
It should look like this:
Old 01-23-2008, 01:08 PM   #19
Fav Mod: Flat 6
IWSTI Addict since: Jun 2006
Another way to check if it's the clutch is to get up to about 30, then shift into 4th, punch it, if the RPM's go way too high, then you know it is the clutch. I'd also take off the intake until you get it tuned.
ACHAHockey is online now   Reply With Quote
Old 01-23-2008, 01:10 PM   #20
Car: 04 PSM
IWSTI Addict since: Feb 2006
Are a clutch and flywheel the only thing you need to consider while remaining reliable at stage 2?
BobDigi5060 is offline   Reply With Quote
Old 01-23-2008, 01:18 PM   #21
Car: 04 JBP STi
yeah it looks like that...
Old 01-23-2008, 01:18 PM   #22
NIИja
The stock clutch will handle Stage 2 power
. It's a wear item though. It will go out after a certain (xx,xxx miles) mileage. Just like your brakes wear out.
Old 01-23-2008, 01:27 PM   #23
Car: 04 JBP STi
what clutch combo should i go with?
Old 01-23-2008, 01:30 PM   #24
NIИja
I would first try the clutch tests suggested above. Parts + labor are not cheap.
Old 01-23-2008, 01:35 PM   #25
Fav Mod: rick roll
IWSTI Addict since: Jul 2007
Originally Posted by D1SMember View Post
the OP's sig is soo funny! was that aired just recently or something? looks like he broke his face!
omg i cant stop laughing from that i just went to youtube and watched the whole thing
ballinSTI is offline   Reply With Quote
Old 01-23-2008, 01:43 PM   #26
Car: '05 Aspen White STi
Fav Mod: Fix-it tickets!
Probably the ACT street disc.
But back to your problem, have you checked everywhere for leaks? It sounds like you have a leak, if it isn't your clutch. My clutch is slipping like a mofo and I can still boost. Check and make sure that your MAF sensor is sealed tightly and check EVERYTHING pre-turbo that you might have changed. Good luck
importfanatic17 is online now   Reply With Quote
Old 01-23-2008, 02:09 PM   #27
Car: 04 Sti
IWSTI Addict since: Sep 2006
what did you look up to find that video?
bigJP is offline   Reply With Quote
Old 01-23-2008, 07:16 PM   #28
Car: 04 JBP STi
i have done this and the RPM's go way too high, as if im just revving the engine.. theres no acceleration whats so ever..
i put the car in fifth and sixth gear and my car stalled.. i also took the k&n off and put the stock airbox back in.. and i run into the same problems.. my car feels like its getting worse and worse..
im going to check all the connections tomorrow and re-do everything.. but if it is the clutch.. can someone recommend where i can buy a good clutch combo and what part numbers i would need..(for cheap)... im leaning towards the ACT clutch combo because i have heard good things about them.. but the only thing is i dont know what to look for?? my goal is to get around 400whp.. so what ever can handle that for a long time.. is what i'll probably get..
i appreciate you guys really helping me out...
Old 01-25-2008, 05:37 PM   #29
Car: 04 JBP STi
okay so i went to WORLD ONE PERFORMANCE today.. and they said it is the clutch.. so i ended up ordering the ACT clutch combo..
PART #SB4-HDR6
anyone have any opinions of this combo??
i also went ahead and purchased the ACT streetlite flywheel...
