| | #16 |
| Junior STI Driver Car: 04 JBP STi Fav Mod: Me Driving The Car Location: Tacompton, Washington Posts: 65
IWSTI Addict since: Apr 2007 Trader Rating: (2) | if it is the clutch.. what after market clutch can i go for?? my goal for my car is get around 400whp.. so i want something that can be reliable at that power... This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 |
| Spec C Club Car: 08 STi, SSM Location: Edmonds Washington Posts: 1,428
IWSTI Addict since: Dec 2005 Trader Rating: (0) | find a wide open area where you won't hit anything. put the car in neutral and stand on your brakes, put the car in fifth or sixth gear and slowly let the clutch out. If you don't kill the car, your clutch is toast. It sounds like it's done. Also check your MAF o-ring, I'm betting you cut it when you installed the K&N. |
| | #19 |
| Spec C Club
Car: Bugeye, '95 Porsche Fav Mod: Flat 6 Location: Buffalo, NY Posts: 2,060
IWSTI Addict since: Jun 2006 Trader Rating: (3) | Another way to check if it's the clutch is to get up to about 30, then shift into 4th, punch it, if the RPM's go way too high, then you know it is the clutch. I'd also take off the intake until you get it tuned. |
| | #22 |
| NIИja | |
| | #24 |
| NIИja | |
| | #25 |
| STI Driver | |
| | #26 |
| Spec C Club Car: '05 Aspen White STi Fav Mod: Fix-it tickets! Location: Sacramento, Ca Posts: 1,759
IWSTI Addict since: Apr 2007 Trader Rating: (5) | Probably the ACT street disc. But back to your problem, have you checked everywhere for leaks? It sounds like you have a leak, if it isn't your clutch. My clutch is slipping like a mofo and I can still boost. Check and make sure that your MAF sensor is sealed tightly and check EVERYTHING pre-turbo that you might have changed. Good luck |
| | #27 |
| STI Driver | |
| | #28 | ||
IWSTI Addict since: Apr 2007 Trader Rating: (2) | Quote:
i have done this and the RPM's go way too high, as if im just revving the engine.. theres no acceleration whats so ever.. Quote:
i put the car in fifth and sixth gear and my car stalled.. i also took the k&n off and put the stock airbox back in.. and i run into the same problems.. my car feels like its getting worse and worse.. im going to check all the connections tomorrow and re-do everything.. but if it is the clutch.. can someone recommend where i can buy a good clutch combo and what part numbers i would need..(for cheap)... im leaning towards the ACT clutch combo because i have heard good things about them.. but the only thing is i dont know what to look for?? my goal is to get around 400whp.. so what ever can handle that for a long time.. is what i'll probably get.. i appreciate you guys really helping me out... | ||
| | #29 |
IWSTI Addict since: Apr 2007 Trader Rating: (2) | okay so i went to WORLD ONE PERFORMANCE today.. and they said it is the clutch.. so i ended up ordering the ACT clutch combo.. PART #SB4-HDR6 anyone have any opinions of this combo?? i also went ahead and purchased the ACT streetlite flywheel... This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
