Old 01-13-2008, 10:58 PM   #1
Default P0031 Problem
Hey all,
I've recently thrown a P0031 CEL. This, of course, would indicate that my front O2 sensor is bad, if I'm not mistaken. However, I just replaced that front o2 sensor ~3weeks ago. I was previously throwing a P0139 (i think) when the first one went bad. I have a Invidia TBE, Invidia equal length header w/ uppipe, APS CAI, Perrin lightened crank pulley, NGK one-step-colder plugs, and the Accessport (I'm running the stage 2 93oct HWG map right now). After i replaced the first o2 sensor with another OEM model, things returned to perfect. The idle surging was gone and the car was running perfectly. Unfortunately, as I mentioned, that only last 3 weeks. Now I'm throwing a P0031 CEL. I've seen that switching to a wideband o2 sensor MIGHT be helpful, but that seems to only sometimes be the case. I've also seen that going back to the normal temp NGK plugs might cure the problem. Any suggestions as to what I can do? Replacing that damn o2 every couple of weeks just won't be economical, ya know? haha
Kev
Indianapolis, IN
knemeth is offline   Reply With Quote
Old 01-16-2008, 08:31 AM   #2
Fav Mod: Tires and Brakes!
Default Re: P0031 Problem
p0031 is heated 02 sensor control circuit low
I can PM you a .pdf of diagnostic steps to track your gremlin if you want
gosu is offline   Reply With Quote
Old 01-18-2008, 12:11 AM   #3
if you could do that, that would be kick ass
thanks!
Old 02-10-2008, 12:54 PM   #4
Car: 05 OBP STI
Fav Mod: STG 2
i pulled the same code would you be able to help me out too? thank you .
EvO KiLLeR 2005 is offline   Reply With Quote
Old 02-10-2008, 06:31 PM   #5
thanks!
still need it?
pm me your email
