IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > ECU Tuning & Performance Electronics
Old 12-15-2007, 07:35 PM   #1
Car: 07ltd UGM
Default Preparation for protune
I know the basics, but is there anything to look out for before a protune. I have a cobb dp and heat shield. Is it a good idea to have the heat shield off so the tuner can access the bung. Any help appreciated. I searched but if a protune prep link exists point me in the right direction. Thanks
J
j07sti.ltd is offline   Reply With Quote
Old 12-15-2007, 07:39 PM   #2
Car: 07 SWP STI LTD #484
Fav Mod: RCE Yellows
Default Re: Preparation for protune
here's a link: CobbTuning.com - Dyno Tuning Checklist v1.00
gr00vy07 is online now   Reply With Quote
Old 12-15-2007, 07:42 PM   #3
Car: 07ltd UGM
I found that one. Thanks. Any thoughts on the heat shield?
Old 12-15-2007, 10:18 PM   #4
Car: 07 OBP STI
Fav Mod: Sundays and Boxers
I am not sure how most tuners do it... but during my tune no sensors were placed anywhere near the heat shield. I had it installed before I arrived and it was never messed with.
The prep stuff is kinda worthless for a new car if you ask me. Just use your brain. Don't bring in a car in piss poor condition. A tuner is going to do what they do best... put your car on a dyno, hook up a computer, and get down and dirty. I have not hear much about removing the heat shield. 99% of the people on these boards go to their tune with all the parts installed (in my case tbe, cai, fuel pump, heat shield) and leave with a tuned car that runs great.
Side note: Tuners love to tune for numbers. A heat shield only contributes to higher numbers, so they would probably prefer to leave it on to avoid heat soak.
StylesJim is offline   Reply With Quote
Old 12-15-2007, 10:33 PM   #5
Car: 08 CBR1000RR
Fav Mod: None
Most tuners will put the 02 sensor on the back of the tailpipe, but this can vary. If your only mod is an exhaust, then I would just make sure you don't have any exhaust leaks. For future reference when you start to add more parts, I would perform a boost leak test as well prior to any tuning. Plus if you haven't considered it, I would get a race gas tune or race gas mixed with pump. Good luck!
Old 12-15-2007, 10:44 PM   #6
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
I wonder how accurate that a/f off the tail pipe is if you have a cat. Because arent they suppose to burn of some of the unburnt fuel in the exhaust so would that make your car seem leaneer than what it is?
CenCali07STI is offline   Reply With Quote
Old 06-13-2008, 06:47 PM   #7
Car: 06 STI
How many of you are getting compression and leak down tests done before a protune like they suggest? It is a great idea but I'm not showing any signs of problems.
Better safe than sorry? Thanks.
oc1806STI is offline   Reply With Quote
Old 06-13-2008, 06:51 PM   #8
Car: 07 STI
Fav Mod: Zzyzx Coilovers
I'd do a compression test. If the numbers are consistent then I don't see any reason to get a leak down.
