Old 12-15-2007, 02:34 PM   #1
Car: 04 Subaru WRX STI
Fav Mod: invida header
IWSTI Addict since: Jul 2006
Default Please Help!
i woke up today and decided to clean my k&n and do some other little things to my car. i took out my stock topmount to clean all of the dirt and grit that has accumulated since my turbo install and i set a wrench by the alternator. i saw a spark arc from somewhere (assuming the alternator to ground). i went to start the car and there was nothing. there was the door chime, but no fuel pump surge, no gauge sweep, no ticking and def no turning over. my interior lights dont work and neither does my key fob when i attempt to lock and unlock the doors.... i swapped the battery with another car and got the same results. I tried to reset the ecu via my axcess port, but because the cars acc wont even turn on it cannot comunicate with the ECU. i checked all of the fuses in the dash and in the engine bay... i even took out the ecu fuse and still nothing. the hazards, brake lights, horn, and door chime work, and thats it. any help appreciated thanks in advance...
Eric
just another sti is offline   Reply With Quote
Old 12-16-2007, 07:26 PM   #2
Default Re: Please Help!
turns out it was just the 100 amp fuse in the engine bay. though it didnt look broken, when i removed the plastic cover i saw that there was a brake in the wire.
Old 12-16-2007, 07:36 PM   #3
Car: 06 STi Spec C
Fav Mod: The STi experience
IWSTI Addict since: Oct 2006
Nice man, I'm glad everything worked out fine so you can get back on the road.
06SpecC is offline   Reply With Quote
