Old 10-23-2007, 10:59 PM   #1
Car: Aspen White 07 STi
IWSTI Addict since: May 2007
Default 07 STI owner with omori mech boost gauges please help!!
Hi all
i was going to do the 52mm omori mech boost gauges installation tonite, I have run into some issue, and after spending almost 2 hrs of looking and searching inside the engine bay, and i still can't find the right vacum hose to tap for the boost gauge hose reading.
here is the case:
I got the gauge used, its mint condition and no damage at all.
it comes with the connection wire and the plastic 3 way "T" connector with a gold restrictor inside one of the connector outlet.
I know that, I need a bigger 3 way T connector(p-94) to get it tap into the stock BPV vacum hose for an easy installtion. but, other people also say that you can also just tap into the intake manifold vacum hose, cuz, its the same size hose as what omori supply with and it will work with the omori 3 way T connector.
so, I spend hour after hour looking for the intake manifold hose and vacum hose or throttle cable or beige check valve.
so, my question is, can anyone help me or show me a picture of which vacum hose that i am suppose tap my 3 way T connector into in an 07 sti.
all input are welcome
jay
njsy2k is offline   Reply With Quote
Old 10-24-2007, 07:24 AM   #2
Default Re: 07 STI owner with omori mech boost gauges please help!!
any tips? any comments?
Old 10-24-2007, 01:12 PM   #3
Car: 02 WRX faux STi
Fav Mod: roof rack
IWSTI Addict since: Apr 2003
connect at the bov, right after the 90
jaxscuby is offline   Reply With Quote
Old 10-24-2007, 04:30 PM   #4
yes, i know that i can connect it through the stock bvp vacum hose, but the thing is, the y-t connector that comes with the package is way to small to fit with the stock bvp hose.
and that is why i am aksing for help, to see if there is other location to tap the y-t connector to.
jay
