Cobb Accesstuner Costs to protune on 93 and E85 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Cobb Accesstuner: Costs to protune on 93 and E85
Old 07-13-17, 01:20 PM   #1
NotTodayEvo
Active Participant
Car: 2016
NotTodayEvo is an unknown quantity at this point
Default Costs to protune on 93 and E85
I've been searching the web quite a bit and have not found much on this topic. I will be converting my 16 STi to an E85 flex-fuel system soon and am trying to get an idea on how much I should expect to spend on a protune. Realistically I will need a tune for both pump gas and E85. I'm sure they will also tune for the intelligent, sport, and S# modes as well. Any experience or advise would be appreciated!
NotTodayEvo is online now
Old 07-13-17, 01:41 PM   #2
Leemanfor
Car: 2012 Satin White STi
Leemanfor is on a distinguished road
Default Re: Costs to protune on 93 and E85
Hard to give you a realistic number as they all vary
I know a certain protuner around here, considered the "best" in Colorado charges ~1000 for flex fuel setup.
Leemanfor is offline
Old 07-13-17, 01:53 PM   #3
blacknblue06STI
Advanced Mastery Level IV
Car: Black, 06' STI
Fav Mod: Cobb Accessport V2
blacknblue06STI has a spectacular aura aboutblacknblue06STI has a spectacular aura about
Don't forget cobb has flex fuel kit and tune on the accessport available.....quite convenient
blacknblue06STI is offline
Old 07-14-17, 04:40 AM   #4
NotTodayEvo
Active Participant
Car: 2016
Yep I thought about it, but I figured if I have to get injectors in there I might as well take off the intake manifold and swap out the TGVs while I'm at it which would require a tune
Likes 1 Dislikes 0
Old 07-14-17, 05:24 AM   #5
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
yamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud ofyamahaSHO has much to be proud of
Stock turbo? I personally wouldn't bother with the TGV deletes if you're thinking you have to pull the manifold for injectors. You can get the injectors without pulling the manifold. You're unlikely to get any gain from the TGV deletes, which isn't worth the work at this point in time, IMHO.
-Jason
yamahaSHO is offline
Likes 1 Dislikes 0
Old 07-15-17, 08:33 AM   #6
revilingfool
Advanced Contributor Level 1
revilingfool is on a distinguished road
its better to pay a little more and leave with a smile on your face than try and get the best deal and constantly wonder if there was a better one out there. Call some shops, take it to the one that meshes with you the best. There's always a chance you will have to take it back again as well.
revilingfool is offline
Old 07-21-17, 11:33 AM   #7
earth0
Advanced Contributor Level 5
Feedback Score: 2 reviews
Car: 15 STI
Fav Mod: ELH E85
earth0 is on a distinguished road
$800 for tuning both 93 and E85 Flex (COBB). As yamahaSHO advised- No need TGV Deletes if no upgrade turbo.I'd suggest doing ID1300 and a better fuel pump to support future bigger turbo if that your goal. Safe money invest on bigger Inj and FP if you plan to go further.
earth0 is offline
Old 07-24-17, 11:45 AM   #8
NotTodayEvo
Active Participant
Car: 2016
Thank you both for the advice here! I've been going back and forth on this one so I'm glad it was brought up. My initial plan was the basic intake/exhaust, but then after reading I needed to upgrade the fuel system I figured I've always wanted E85 flex fuel so I might as well take advantage of the cobb system since I'm gonna spend the money.
So now my question is... what's your advise on these following mods when I upgrade to flexfuel? Keep in mind I plan on keeping the stock turbo for a long time. Only reason I'm considering the additional mods below was because my tuner said I might as well do these mods when I remove the intake manifold because the injectors are much easier to install with the manifold off.
-Perrin turbo inlet pipe
-Cobb or grimspeed EBCS
-airpump delete mod
-TGV mod (which now I'm starting to agree with you both)
-grimmspeed AOS
I did read some install forums and watch some YouTube videos that say the intake manifold doesn't need to come off to change the injectors. I realize the AOS and airpump delete don't really improve performance, but do you think I'd see gains or benefits from a EBCS, TGV delete and inlet pipe combo??
Also note my current mods are invidia catted TBE and I have a Cobb intake w/ airbox sitting around for when I do move to stage 3+
Old Yesterday, 07:03 AM   #9
earth0
Car: 15 STI
Fav Mod: ELH E85
-airpump delete mod
-grimmspeed AOS
Hey,My suggestion:
-Perrin turbo inlet pipe : No need
-Cobb or grimspeed EBCS : YES
-airpump delete mod : No need
-TGV mod (which now I'm starting to agree with you both) : No Need
-grimmspeed AOS : YES, But not for track use.
You may need to upgrade TMIC and consider ELH when upgrade to e85. The ELH+e85 will definitely increase your TQ upto 400+ and it does benefit the engine. What i had on now is Tomei ELH and Grimmspeed TMIC. both work Great!
earth0 is offline
Old Yesterday, 07:42 AM   #10
yamahaSHO
BROtuner
Car: 2005 WRB
I would not upgrade your intercooler (most aren't actually an upgrade) as E85 makes what you have go further and you can run a larger turbo on that intercooler.
ELH is a good change regardless of fuel or power level. E85 and "stage 2" will do 400+ ft-lbs already.
-Jason
