Cobb Accessport Cobb Accessport Battery Readings - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Accessport Cobb Accessport Battery Readings
Old 03-19-17, 01:05 PM   #1
STi-mon
Becoming A Contributor
Car: Black Opal 2011 STi
Fav Mod: COBB Accessport
STi-mon is an unknown quantity at this point
Default Cobb Accessport Battery Readings
Hey everyone,
So I decided to test out my car battery. It's a brand new battery but I'm wondering if it might be faulty.
I hooked up my Cobb Accessport and set the gauge settings to battery. I turned on lights air conditions and all other devices that can drain battery and started the car.
The min/max values range is 9.44 to 14.47 according to the Accessport.
Basically I just want to know if the min reading of 9.44 are signs of a faulty battery seeing as I've only had it for 2 weeks.
Thanks!
STi-mon is offline
Old 03-19-17, 04:09 PM   #2
blacknblue06STI
Advanced Mastery Level IV
Car: Black, 06' STI
Fav Mod: Cobb Accessport V2
blacknblue06STI has a spectacular aura aboutblacknblue06STI has a spectacular aura about
Default Re: Cobb Accessport Battery Readings
Originally Posted by STi-mon View Post
Hey everyone,
Thanks!
it should stay above 12V with the engine off, with the engine running it will stay between 13.5-14.5 in a healthy charging system and accessories turned on.
The battery should hold most of that chargebwhen the engine is shut off, you can watch the battery reading on the accessport and when you turn off the engine it will slowly drop into the 12's. If it continues to drop quickly lowerthan that into the 11 and 10's then the battery is weak, and should be replaced.
Your high read of 14+ volts indicates the alternator is working properly.
blacknblue06STI is offline
Likes 2 Dislikes 0
Old 03-20-17, 05:15 AM   #3
STi-mon
Thanks for the info!
STi-mon is offline
