| Junior STI Driver | can some one tell me if my mph in the quarter mile is off for my time i went a 13.55 @ 98.21mph 1.77 60 ft the car is all stock any tips or suggestions i have been compareing my mph to everyone else's and my seems way low This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 | |
| Junior STI Driver | Quote:
ok with me i don't think it's me personally that day it was 75 degrees and that run probually would of been a 13.4 or a high 13.3 if it was 25 degrees cooler outside. it's just people on the forum and at the track are going 13.4 and 13.3 at high 99mph to low 101mph. i will have to see if weather is the factor i don't think shifting is because i was shifting at 7k and 6.5k and it did not make a big diffrence.and i thought my 60ft was pretty good could be a little better but good non the less. | |
| | #5 |
| GT R US
Car: CUTN EDG project Fav Mod: $20. mudflaps from auto zone Location: my cave Posts: 5,882
IWSTI Addict since: Dec 2003 Trader Rating: (1) | according to this, the 1-2 and 4-5 shifts should be at redline. in any event, i think 6000 rpm is too early. http://www.morgancountytn.com/slowri...vs-torque.html |
| | #6 |
| Spec C Club Car: 2008 Fitrari Red Fav Mod: Getting 40mpg Location: North Jersey Posts: 1,533
IWSTI Addict since: Jan 2004 Trader Rating: (8) | Some key factors on obtaining a good ET: -Get out of first gear as quickly as possible. Once you launch and begin to build speed in first gear, you should already be shifting into second. You should NEVER redline first gear. -Practice, practice, practice shifting. Your right foot should hardly have to come up when tapping that clutch pedal. If it is, you are shifting too slow. -Quick shifting, a good launch, and most importantly- a properly maintained vehicle(!) will help you cut down ETs quicker than anything. |
| | #7 |
| Senior STI Driver Car: 05 Subaru WRX STi Fav Mod: Flux Capacitor Location: Elkton, Md Posts: 318
IWSTI Addict since: Feb 2006 Trader Rating: (8) | Cooler weather will definately help you too mike. My car when 2 tenths faster stock when the temp went from 70 to 55 degrees. Shifting is huge though. Makes a big difference. |
| | #8 | |
| HowTo Contributor Car: 06 STi Fav Mod: 10.91 at 127.08 Location: Ontario Canada Posts: 878
IWSTI Addict since: Mar 2006 Trader Rating: (6) | Quote:
I am basing my 6,000 rpm shift point on a good torque range verses a good hp range. But my thinking is probably wrong, as my times were the same (12.8 range)as always, but my trap speed was 2 mph slower. Next time I;'m at the track I will try their recomended 1-2 at redline and 4 to 5 at redline and the rest at around 6500 and then 6000 and see what happens. I may be loosing speed by shifting at 6,000 rpm from 4 to 5. That will have to wait till spring as the season is done up here Last edited by jasv11; 11-18-2006 at 09:40 AM. | |
| | #9 |
| Junior STI Driver | ill have to try shifting out of 1st sooner i power shift every gear except fifth so i don't think i can shift any faster hopefully with that and some cooler weather i will be good to go thanks for your guy's help This ad is not endorsed by this member. Please register or login to hide this ad. |
