Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Driving & Motorsports > Driving Tips & Techniques
Old 10-23-2006, 12:58 PM   #1
IWSTI Addict since: Oct 2006
Default Driver error or? Shifting, engine balk, 1st up to 2nd?
I get rpm between 4 and 5k, as a for instance, there seems to be an engine bog when I hit 2nd? Only 1st to 2nd. !!!!!!!! Why not second to third too?
My first turbo!? The bog, or balk varies. If i take more time, it seems to help.
Thanks
october is offline   Reply With Quote
Old 10-23-2006, 02:20 PM   #2
IWSTI Addict since: Feb 2005
Send a message via AIM to jermdeez
you need to get some mods buddy. With stage 2 my 4th gear feels like my 2nd use to.
jermdeez is offline   Reply With Quote
Old 10-23-2006, 02:55 PM   #3
Car: 05 Subaru STI
IWSTI Addict since: Jul 2005
Thanks
thats called turbo lag.
it gets better with mods. (meaning the lag gets reduced)
Illusive is offline   Reply With Quote
Old 10-23-2006, 03:02 PM   #4
IWSTI Club Level 1
Car: The Spaze Mobile
Fav Mod: Tuning
IWSTI Addict since: Jan 2006
Sounds like your dropping the clutch before you get on the gas....The STi has a very small 'sweet spot'. It just takes practice.
flatthump is online now   Reply With Quote
Old 10-23-2006, 03:19 PM   #5
Default ok
so it makes sense this happening ONLY from 1st up to 2nd?
I had accepted it as an oddity till the other day, when one bogged launch to 2nd seemed a tad severe. You can't watch my clutch engagement, so I am trying to rule that out . Just that one time, the lag seemed nearly dangerously..what? almost like it wanted to stall.. almost. It only happened that way once, but it got my attention.
I will start being more attentive to my feet. But why not from 2nd to 3rd?
Thank you, especially to those patient one's who are fairly sure it is my error in technique.
Old 10-23-2006, 03:23 PM   #6
Quote
flatthump Sounds like your dropping the clutch before you get on the gas....The STi has a very small 'sweet spot'. It just takes practice."
By 'sweet' you mean, a weakness or a strength? I am not clear about the small "spot".
A short ( aka "small sweet spot" ) opportunity to screw up or to hit a wave of power?
I am starting to have a hunch you are right- premature release of left foot.
Thanks
Old 10-23-2006, 03:24 PM   #7
Car: 06 Subaru WRX STI
IWSTI Addict since: Jun 2006
Send a message via AIM to dukenukem
thanks for the replies, i too was facing the same issue where the sti would sort of bog/ shudder a bit when i was engaging 2nd from 1st. The only way around it was if i let go of the clutch real slow but still there is a slight lurch as the gears engaged. Is this bit of jerk normal for manual cars? Sorry .. this is my first manual in many many years so i am still figuring my way out.
dukenukem is offline   Reply With Quote
Old 10-23-2006, 04:39 PM   #8
IWSTI Addict since: Apr 2006
it`s all about timing
play around little bit.
when you drop the clutch at the same time you should press gas...
but if you press gas too much.. you will feel the jerky again..
RyanLee is offline   Reply With Quote
Old 10-23-2006, 04:43 PM   #9
Default I will experiment.
But I caught it the other day, where the sensation was almost like running out of gas, which i was not. This car is excellent and nearly new.
I plan on playing with it a lot. I just want to rule out anything mechanical. I am happy to own this as my lack of knowledge of turbos. I have never had this issue before, in previous 6 speed, and numerous 5 speeds and 4 speeds.
The turbo is the odd man out. but why ONLY in 1st to 2nd and not 2nd to 3rd? Anyone care to illuminate?
Old 10-23-2006, 07:31 PM   #10
Car: 05 Blue/Gold
Fav Mod: Blinker Fluid and Piston Return Springs
IWSTI Addict since: Dec 2004
It seems to me that any lurching or jerkiness in shifting comes from the same basic source. The speed of the drivetrain is not matched well with the speed of the engine. If the engine is spinning significantly faster than the drivetrain, you get the big lurch forward when coming off the clutch. If the drivetrain is spinning faster, you get the lurch backwards. Things probably get smoother at higher speed (higher gears) because there is a lot more inertia in the car and drivetrain, smoothing things out.
Not sure what is happening with you. But if you are having any jerkiness, in either case the answer is the same: Be smoother. This is regarding both the throttle and the clutch. It is difficult to get 100% right 100% of the time. But any racer will tell you smoothness = quickness.
IlliniSTi is offline   Reply With Quote
Old 10-23-2006, 07:39 PM   #11
With respect: It is not jerky or lurching, as in TOO MUCH misplaced power, the way a teens first attempts at shifting often go, with the poor Dad crossing his fingers, not at all. This is a bogging, a balking a major LOSS of POWER for a second or so.
I never had this problem with NA engines. So this relates to turbo boost and my lack of understanding of it, yes?
I do not understand boost and waste gate etc. I thought having the rpm at around 4500/5000 gave me sufficient power to just shift as I always do. i am an older guy. OOOOOOOOOOweeeeeeeee. I guess I have to relearn. But the car almost stopped, is that normal? Can you ppl make this happen ( near stall ) with improper use of turbo/clutch at 4000 - 4500 rpm?
Old 10-24-2006, 07:49 AM   #12
Car: 04 STi - Aspen White
Fav Mod: Cobb Short Shifter
it sounds like you're letting the revs drop too far while shifting to 2nd. i could be totally wrong though since i can't watch you drive.
you say you're shifting out of 1st around 4k, but what rpm is it at after you get 2nd fully engaged?
the 1-2 shift is the most difficult on any manual car b/c the change in gear ratios between the 2 is the biggest and b/c they're low gears. moreso on these cars than any other i have driven, b/c of the AWD i think. to make my 1-2 shift smooth and quick i always give gas as i'm bringing up the clutch to keep the revs from falling too far too fast.
i don't see how the turbo really comes into play other than just the lag of waiting for it to spool all the way up after getting back on the gas.
jomotopia is online now   Reply With Quote
Old 10-24-2006, 07:51 AM   #13
Fav Mod: The Newest One!
IWSTI Addict since: Sep 2005
I have had the same problem when I first got the car. And the above would have been my answer as that is what I did and it worked for me.
Old 10-24-2006, 10:27 AM   #14
Car: Z06
Fav Mod: LS6
IWSTI Addict since: May 2006
get an accessport, problem solved
kessler89 is offline   Reply With Quote
Old 10-24-2006, 10:44 AM   #15
Car: 06 STI
Fav Mod: Stock!
IWSTI Addict since: Feb 2006
Grabby clutch and turbo lag causes this.
Rmiller is offline   Reply With Quote
