Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Driving & Motorsports > Driving Tips & Techniques
Old 11-10-2006, 12:28 PM   #16
Car: RIP 02 WRX
IWSTI Addict since: Dec 2005
Originally Posted by rgt
Ihave big feet so i can brake with my toe and the ball of the front part of my foot and then i blip the gas with the side of foot. I keep my heel anchored on the floor. Im not for sure if this is the best way for me to do it but it works when im hard on the brakes and downshifting. The next phase will be learning how to keep the revs up in a turn.
Ideally (i.e. not on the street) you will be downshifting before you turn.
Old 11-15-2006, 11:52 AM   #17
Car: Black '05 STi
Fav Mod: Dealer delete option.
IWSTI Addict since: Oct 2004
Originally Posted by RCane
If you learn how to heel-toe, it just becomes part of your normal driving and rev matching while down shifting is easier. If you're breaking to a light you just rev match down through the gears while breaking so you're always in the correct gear when it's time to floor it again. Assuming we're all trying to increase our driving skills, "necessary" really has nothing to do with it... It's the most efficient way to combine braking and down-shifting.
.... +1
Conekiller13 is offline   Reply With Quote
Old 11-15-2006, 01:11 PM   #18
Fav Mod: FYI, I'm a dude
IWSTI Addict since: Mar 2005
i didn't learn to drive stick until i got my sti. it was my first manual tranny car. you'll get the rev-match downshift easily. just takes a little practice. clutch-in, rev match and shift simultaneously, clutch out. after that, try heel-toe, double-clutching, and heel-toe double clutching. this is the order i learned in.
Old 11-15-2006, 04:12 PM   #19
Car: 06 STI
Fav Mod: Prodrive oval tip
question.. when you downshift, do you let go of the gas when you press the clutch in? or do you just keep your foot on the throttle while pressing the clutch? know what im talking about?
Old 11-15-2006, 05:49 PM   #20
Car: 07 STI OBP
Fav Mod: flat black rims
IWSTI Addict since: Jul 2006
Send a message via AIM to JustinH
^ uhm; clutch in(without giving gas, like u normally do), blip throttle to match next gear's rpm while you are moving the shifter to the new gear, then let out and it should be pretty smooth
JustinH is offline   Reply With Quote
Old 11-15-2006, 09:33 PM   #21
Car: 06 STI
that's how I usually do it but i was wondering if it'll use up clutch more if I keep the throttle in the same position when i clutch in to downshift instead of throttle off then clutch in.. etc..
Old 11-15-2006, 09:44 PM   #22
Car: 06 Subaru WRX STi
Fav Mod: seatbelt beep delete
IWSTI Addict since: Feb 2006
i learned how to rev match before heel toe, just made sense to me. once you've learned how to rev match, you'll do it all the time, without even thinking about it. It just makes downshifting so smoooth. the only way i can describe it is, clutch in, blip the throttle as your shifting the stick into the lower gear, clutch out.
06AspenWhiteSTi is offline   Reply With Quote
Old 11-15-2006, 10:55 PM   #23
Car: 06 STI UGM
Fav Mod: (o)(o)
Double Clutch FTMFW!!! The gears def shift easier when double clutching (downshifting!)
Do some research on the net about double clutching! Its not hard, but some people seem to have a mental block when it comes to it!
Everyone should be double clutching (Which of course includes rev matching!)
Jay
JAYMAC10 is offline   Reply With Quote
Old 11-16-2006, 06:49 AM   #24
double clutch technique if you can't find it:
1. clutch-in
2. shift to neutral
3. clutch-out
4. rev-match
5. clutch-in
6. shift to lower gear
7. clutch out
the key is to be smooth and quick. don't over think it either. just do it. heel-toe double clutch down shifts are the same, but you're doing the above while braking. watch the gary sheehan foot-box video. that guys is a master of the heel-toe double clutch.
Old 11-16-2006, 07:16 PM   #25
Car: 02 2.5RS
Fav Mod: WRX trunk swap!
Send a message via AIM to [z0ne] Send a message via MSN to [z0ne]
1. clutch-in
2. shift to neutral
3. clutch-out
4. rev-match
5. clutch-in
7. clutch out
Heel/toe is definitely one of the best driving techniques one can learn. It really improves the ride quality and doesn't stress the drivetrain. Anyway, here is a direct link to Gary Sheehan's "Footbox" video: http://www.teamsmr.com/movies/Footbox%20Small.wmv
[z0ne] is offline   Reply With Quote
Old 11-19-2006, 01:59 AM   #26
Car: 06 AW STI
Fav Mod: Hardwired 8500
IWSTI Addict since: Feb 2005
Originally Posted by haasSTI
ditto. Double clutching is super smooth in an STI
i double clutch downshift on instinct now in everything but the cobra. that engine revs down to fast to catch it.
do u heel toe with your hell on the gas and toe on the brake right?
NorCALSpeed is offline   Reply With Quote
Old 11-19-2006, 02:31 AM   #27
Car: '05
Fav Mod: AP
IWSTI Addict since: Apr 2006
1. clutch-in
2. shift to neutral
3. clutch-out
4. rev-match
5. clutch-in
7. clutch out
i think you have too many steps in there. it's not that complicated. heel toe is rev matching/double clutching, right?
brake, clutch in, blip (rev match) down shift, and clutch out.
dannyblaze_07 is offline   Reply With Quote
Old 11-19-2006, 03:10 AM   #28
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
rev matching is waht you said, lokutus has the double clutching right. They are 2 seperate things.
Old 11-19-2006, 03:29 AM   #29
Car: '05
Fav Mod: AP
oh i see, so rev matching is just one of the steps used to execute double clutching, right?
Old 11-19-2006, 10:05 AM   #30
520
Car: 03 EVO
Fav Mod: stock :(
in rev matching you only push in the clutch once and let it out once. So while the clutch is in you blip the gas and put it into gear and the let clutch out. Obviously you do it quickly.
In double clutching you push in clutch twice and clutch out twice.
you are in N when you blip the throttle in double clutching.
