Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Driving & Motorsports > Driving Tips & Techniques
Old 05-08-2006, 12:05 AM   #1
IWSTI Addict since: Apr 2006
Default Pls share your shifting rpm?
For those who have a STI. AT what rpm do you shift gears for the following reasons.
1> Crusing, but wanna get going fast.
2> Crusing, but wanna save gas as well
3> Regular street driving, but wanna be the 1st in line.
Eg. from stop to 1st, 1500rpm, then go 3200rpm @ 2nd, etc...
It would be nice if you can share more, that way, we can all learn something here!
Thanks
Old 05-08-2006, 12:59 AM   #2
Car: 06' AspWhite STi *S
Fav Mod: K&N typhoon, Helix TBE,
IWSTI Addict since: Mar 2006
haha.. I just shift around 4000 when i want to go faster..
when i want to conserve fuel i shift at around 2800-3000
Warvetiraq is offline   Reply With Quote
Old 05-08-2006, 10:48 AM   #3
Car: 06 OBP STI
Fav Mod: Blizzak WS-60's
IWSTI Addict since: Nov 2005
I have my shift light set at 3400rpm , and if i feel the need for speed Ill go up to about 6200
Old 05-08-2006, 11:48 AM   #4
I am kind of new to stick and STI (less than 10 days). I kind of find that both 1st and 2nd gears are low, and it does seems to pull much better once I go to 3rd or 4th gears. So, if you wanna to lanuch fast, but not racing speed, what would be your steps?
EL
Old 05-08-2006, 11:56 AM   #5
Car: 2006 STI BLUE
Fav Mod: Fp20g and protune
IWSTI Addict since: Dec 2005
i dont know about u guys but my cars seams to feel better when i drive it like i stold it I mean when i am trying to baby it it feels weird.. Going threw the cayons this weeken it feels like it is at home and FEELS great.... i normaly shift at 4k no jerky going on then .. To low it does not seam to like it .. Just my 2 cents
Old 05-09-2006, 09:21 PM   #6
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
IWSTI Addict since: May 2006
i find that shifting at about 3k rpms from 1st to second is smooth enough. i feel the same way about the car feeling better when i drive harder but right as of right now i am trying to conserve fuel so soft driving for now. 2800-3400 rpm range is good for conserving fuel
Old 05-09-2006, 09:24 PM   #7
1B4DSTI
Fav Mod: M&J Modified
IWSTI Addict since: Jan 2006
i shift near 3800K and if i wanna go fast i go to 6200-6400k
Old 05-09-2006, 09:49 PM   #8
Fav Mod: I can only choose one?
Send a message via AIM to Stargazer
My shift light is set to 5500 rpm (which means when I react, it's usually in the 6000+ range). Check out the May '06 issue of Road & Track for gas saving techniques for driving enthusiats. More fuel is wasted when you gradually accelerate to cruising speed. But that didn't really change my driving habits....maybe, it just justified them .
For me, when traffic conditions allow:
1 = WOT to cruising speed.
2 = WOT to cruising speed.
3 = WOT to cruising speed.
4 (stuck behind slow moving traffic) = shift between 3000-5000 rpm.
All that equates to.... man, I love this car!
Stargazer is offline   Reply With Quote
Old 05-09-2006, 10:04 PM   #9
1B4DSTI
^^yeah so do i
Old 05-09-2006, 10:37 PM   #10
Car: Betsy Blue
Fav Mod: Mud flaps
IWSTI Addict since: Jan 2004
EL
I've been driving stick/shifting on bikes for quite some time now and to tell you the truth, i don't even look down at the tach much anymore (dirt bikes don't have any guages anyway). I kinda like do it by feel/sound. (unless of course i'm on a drag strip or race track) After a while, shifting becomes second nature.
When taking off fast, you'll feel that the car is or has gone past the powerband. That would be a good indication to shift. Give it some time, (definitely more than 10 days) then you'd get the feel for it.
I'm sorry but i doubt there are such things as "cruising" or "regular" driving or "saving gas" on an STi . Or at least i just don't have the patience and dicipline for it.
Might not be much of a help but i hope you learned something.
Earl
Earl is offline   Reply With Quote
Old 05-10-2006, 05:53 AM   #11
Car: 2006 STi Aspen White
This is exactly how I feel. If I baby my car it doesn't feel right. It's very jerky and just doesn't feel normal. Also if I shift under 4k I noticed it is too jerky. This car was not built to be driven like a stock civic.
STiRiDaZ is offline   Reply With Quote
Old 05-10-2006, 06:50 AM   #12
Car: '04.5 STi
My STi isn't my daily driver so when I get in it I drive it however I feel like driving it. So I don't really pay much attention to my shift points. But when I'm focusing on flat out acceleration I shift at 6000 RPM's. The power seems to drop off at about that point.
For fuel conservation your worst enemy is your brakes. You use a lot of gas getting up to speed and the last thing you want to do is use your brakes so you can use another big gulp of gas to get back up to speed. So your best bet is to keep enough space between you and the car in front of you so that if you need to slow down you can put the car into neutral and coast. That way you can slow down without using the brakes and you get extra distance out of the gas you used to get up to that speed to begin with. Driving like this got me an extra 5 mpg out of my daily mule.
Old 05-10-2006, 08:28 AM   #13
Car: 08 White STI
If hauling ass I don't shift until 7k.
GotSTI? is offline   Reply With Quote
Old 05-11-2006, 01:12 PM   #14
Car: 06 white on gold
Fav Mod: 100 lbs of torque
the car will drive perfectly smooth at under 4k, you just need to work a little bit on smoother clutch release. i had to adjust my seat several times before i was in the optimal angle/position for steady/smooth release.
Talon is offline   Reply With Quote
Old 05-11-2006, 01:21 PM   #15
Fav Mod: Perrin 30r Kit
IWSTI Addict since: Apr 2005
if im tryin to be a bat out of hell ill shift in the upper 6k area. have my indicator light set at like 6500.
i try keeping it under 4k when tryin to reserve gas. i try to go lower but i feel like my car is yelling at me for driving it slow already lol
XxSCAxX is online now   Reply With Quote
