| STI Driver | Hi, I'am going to my first autox this weekend. Any tips for me beginner? tire pressure? what not to do? do I stay mostly on 2nd gear and avoid going to 3rd? Thanks for all the help!! This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 | |
| Titanium Member
Car: 05 CGM STi Fav Mod: Bill Location: Neptune Bch, FL Posts: 4,409
IWSTI Addict since: Mar 2005 Trader Rating: (1) | Quote:
I've done 4 so far and I'm completely stock. You can learn a lot by watching others run the track too. See how hard they launch, where they go fast, where they slide, etc. Tire pressures are elevated over stock settings in order to get them to heat up quickly. Of course they can get too hot....so you can dump air out of them and/or spray them with water. I start at 44psi F, and 38psi R for the first run and then adjust from there.... | |
| | #4 |
| S204 Racer Car: Blue 2004 STi Fav Mod: 2001 2.5RS Rally car... Location: Rancho Santa Margarita, C Posts: 2,822
IWSTI Addict since: Apr 2003 Trader Rating: (3) | the shortest line is ALWAYS the fastest line. more tire pressure = more grip (to a point) slow in fast out if you aren't hitting cones you aren't going fast enough if you aren't hitting ABS you are braking like a 9 year old girl walk the course at least 3 times and memorize it so you can drive it in your head BEFORE your first run make a map of the course with notes on it discuss strategies and approaches with guys in DIFFERENT types of cars as well as the same, their insight could be helpful since AWD sometimes acts like FWD and sometimes acts like RWD spend MUCH more time on driver skill than modding the car, except for tires, they are where you should be spending your money Don't worry about cone rash, it comes off with a clay bar and is there to remind you of all the fun you had. Put on sunblock. oh and as Karl said, have fun. I used to charge for this advise at novice schools every year, now you get it for free |
| | #5 | |
| STI Driver Fav Mod: HKS Hipermax RS Coilovers Location: Ohio Posts: 211
IWSTI Addict since: Jul 2004 Trader Rating: (0) | Quote:
Xman is spot on. The only thing I would add is to try to sit shotgun with as many veteran drivers as you can. (Probably during fun runs) | |
| | #6 | |
| Junior STI Driver | Quote:
I'll add some more of his advice that helped me alot: Leave your DCCD in auto, full rear or locking may feel more "secure" or in control sometimes but auto is always faster. And always try to look 2 gates ahead. | |
| | #7 |
| Senior STI Driver Car: 08 Outback XT Black Fav Mod: A good motor Location: Wheat Ridge, CO Posts: 385
IWSTI Addict since: Jun 2004 Trader Rating: (2) | Since no one else has said it, BE SMOOTH! All of your inputs need to be smooth and not violent or sudden. Smooth is fast. Most importantly, have fun. This a kick in the pants. I still get shakey after a good run. I ran my tires at 42-38, but that depends on your surface. Talk to everyone who will listen and try to pick their brain. |
| | #8 |
| HowTo Contributor
Car: 2008 DGM (BBS+Navi) Fav Mod: stock FTL? Location: College Park, MD Posts: 2,197
IWSTI Addict since: Jan 2005 Trader Rating: (9) | Everything Xman said is dead on. And don't worry about hitting a cone, it might leave a little mark, but they will come off. I leave them on since they are hard to see on my black STi, but I still leave them on as little battle scars. |
| | #9 |
| Spec C Club | Put painters tape on the flared areas on the side of trhe front bumper as well as the side skirts. That will save you a lot of elbow grease in cleaning off the cone scrubs. If you don't experience a bit of front end plow you are going too slow. If you felt 'comfortable' during your run, you are going too slow. Make sure you are firmly belted to your seat. Early throttle on! The turbo lag IS noticeable during autoX. |
| | #10 |
| Spec C Club Car: 2008 Fitrari Red Fav Mod: Getting 40mpg Location: North Jersey Posts: 1,534
IWSTI Addict since: Jan 2004 Trader Rating: (8) | Learning to look ahead and where to brake/apply throttle will be the most crucial things to learn first. Smooth is FAST! Herky jerky steering inputs, braking and throttle applications just upset a clean line needed to knock off those precious seconds. |
| | #11 |
| S204 Racer Car: 06 IX MR Location: Minneapolis, MN Posts: 3,666
IWSTI Addict since: Mar 2002 Trader Rating: (12) | The only thing I would add it: Do the cheap-man's harness by: 1.sliding your seat all the way back 2.lock your seatbelt by snapping it forward 3.hold the belt locked with one hand and slide forward using your legs and other hand --doing this method not only locks you in better, but also puts you REALLY close to the wheel and pedals, which is a good for driving the course. I would also suggest these tips when driving the course: 1. Giving up "real estate" loses time, so keep it really tight to the cones 2. Always look 2-3 cones in advance of where you're going 3. Smooth transitions both with the wheel and accelerator. 4. Like Xman said...get into the ABS often...and really push the car. |
| | #12 |
| STI Driver | wow that's alot of advices! thanks, I'll keep them in my mind as I go along. One quesiton regarding the turbo lag, do you guys maintain it "in boost" as much as possible to prevent jerking? |
| | #13 | |
IWSTI Addict since: Mar 2002 Trader Rating: (12) | Quote:
What i'm trying to say is don't worry about "keeping it in boost," worry more about choosing the best gear and not losing time by shifting unless you absolutely need to. | |
| | #14 |
| HowTo Contributor
IWSTI Addict since: Jan 2005 Trader Rating: (9) | I'm a n00b (1st season of auto-x and only 3 auto-xs and a 1 day class behind me so far) but i've learned (and I need to keep learning) to flog the car. Like people have said, push it until you feel the ABS, you hit the rev limiter, you hit cones. If you aren't doing those things you aren't going fast enough. If they offer auto-x schools in your area TAKE it. I went to one, thought I was doing well and then the instructor (an multiple SCCA national champion) took me for a ride in my car to show me what it could do. I was shocked. The car can REALLY do a lot so don't be afraid to push it. That's still my biggest problem, but I'm learning. Also investing in a GC Lock (google it, SoJDM.com also sells them) is a wise use of $35. It will help keep you planted in your seat. I'm ordering one soon. Oh and the most important part -- have fun!! |
| | #15 |
| Junior STI Driver Car: 05 Subaru WRX STi Fav Mod: SFSOC / Pastelito Racing Location: Coral Gables, FL Posts: 199
IWSTI Addict since: Mar 2005 Trader Rating: (0) | One more thing. Leave your ego at home as autocross is a big ego buster for newbies and such. Prepare to be beaten by civics, minis, etc if you have good drivers in those cars in your area. This ad is not endorsed by this member. Please register or login to hide this ad. |
