Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > Driving & Motorsports > Driving Tips & Techniques
Old 06-01-2005, 08:13 AM   #1
IWSTI Addict since: Mar 2005
Default How do you slow down?
Just wondering - what is the best way to slow down: Drop into neutral and brake or downshift through the gears and brake? Personally, I prefer to downshift, allowing the engine to help slow the car and save the brake pads. One thing I've wondered though. Does slowing the car down with the engine put more wear on the engine than it's worth (comparing the cost of brake pads to repairing the transmission)?
Infidel is offline   Reply With Quote
Old 06-01-2005, 08:43 AM   #2
Rev
STI Guru
Car: 06 V70R
IWSTI Addict since: Dec 2003
Send a message via AIM to Rev
When you drop into neutral while braking, you have no engine compression to aid you slow down.
I downshift to assist the braking ...
Old 06-01-2005, 10:48 AM   #3
IWSTI Addict since: Nov 2004
I downshift also. I believe in the manual there is a section on engine braking.
soileauj is offline   Reply With Quote
Old 06-01-2005, 10:53 AM   #4
BOOST
Guest
Posts: n/a
I "rev match" down shift as well, when done properly it's just as smooth as braking.
Old 06-01-2005, 11:27 AM   #5
Car: 08 White STI
IWSTI Addict since: Jan 2004
(ping) right on the money.
GotSTI? is offline   Reply With Quote
Old 06-01-2005, 11:38 AM   #6
Fav Mod: so far? RCE T2s
IWSTI Addict since: Oct 2004
I slam the clutch into the next lower gear and pop the clutch. I can't wait to try that technique out on an autocross course (in mid-turn ;-)
Old 06-01-2005, 01:11 PM   #7
IWSTI Addict since: Apr 2005
Race car engineer ledged, Carol Smith, wrote in his book Drive to Win that braking distances will be shortest when the driver is only concentrating on braking. Shifting and rev-matching will only increase braking distance.
If downshifting while braking makes you stop in a shorter distance, then you are not using the wheel brakes to their fullest potential.
Enchanter is offline   Reply With Quote
Old 06-01-2005, 01:57 PM   #8
Car: 2007 STI
Fav Mod: Perrin GT30R
IWSTI Addict since: Jan 2005
Send a message via AIM to 12SecSTI Send a message via MSN to 12SecSTI
braking? who needs that,
12SecSTI is offline   Reply With Quote
Old 06-01-2005, 01:59 PM   #9
IWSTI Addict since: May 2004
Coming to a full stop? just the brakes, car typically in neutral or not if I'm just coasting froma low gear. Slowing down for a turn? Brake and rev match to correct gear. Brake pads are cheaper to replace than clutches and synchros.
mike_ is offline   Reply With Quote
Old 06-01-2005, 02:10 PM   #10
Car: Beater Van
IWSTI Addict since: Feb 2004
Brakes? Nah, no need. Just slam into the wall and ride it. Just like how I do when doing Nurburgring in Grand Turismo 4. hehe
Hawaii_guy
Hawaii_guy is offline   Reply With Quote
Old 06-01-2005, 11:23 PM   #11
GZA
Super Moderator
Car: 2005 STi
Send a message via AIM to GZA
Hawaii_guy
haha
GZA is offline   Reply With Quote
Old 06-04-2005, 12:38 PM   #12
IWSTI Addict since: Jul 2004
rev mathing (and or heel toe) is used to:
1. keep the car in its powerband for a faster exit out of the turn
2. to keep the car from lurching after a bad downshiftunsettling the weight bias to the front of the car, thus losin some of the grip you had in the rear
3. it just sounds soo cool and tell others that you know how to drive a car, not jsut bang gears
-spyder
jlcool007 is offline   Reply With Quote
Old 06-04-2005, 01:09 PM   #13
Car: working out, studyin
Fav Mod: Gavin My Siberian Husky
Send a message via AIM to ayanami22
rev match is the way to go
ayanami22 is offline   Reply With Quote
Old 06-05-2005, 11:22 AM   #14
IWSTI Addict since: Feb 2005
Send a message via AIM to jermdeez
Double clutch/rev match are cool, i do it to save some brakes, but do you do it each gear everytime?? usually I will downshift to third or so and then ill brake and coast the rest of the way depending on stop sign etc.
jermdeez is offline   Reply With Quote
Old 06-06-2005, 02:16 PM   #15
Fav Mod: IT
IWSTI Addict since: May 2005
In day to day traffic I'll downshift until I get to 3rd, but then I'll disengage at about 1000rpm and coast to a stop. I rev match, usually without heal-toe. Sometimes I will heel-toe or just pop the clutch, but thats a bit rare. I usually give myself plenty of time to stop, wait until I get down to 2000rpm or so, pop the accelerator and shift. If I need to emergency brake I'll just slam the brake and press the clutch in before it gets to stall range.
I'm not concerned about saving pads, but I tend to think it is slightly safer to keep the car in gear while traveling at medium to high road speeds.
I assume (haven't installed WB yet) that the engine cuts fuel at zero throttle >1500rpm like most modern cars. So you might save a bit on gas over coasting, which requires fuel to idle.
Freon is offline   Reply With Quote
