Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > Driving Tips & Techniques
Old 05-20-2008, 08:17 PM   #31
Car: 06 WRX STI SGM
Fav Mod: RCE Yellows, STAGE 1!!!
Default Re: anyone else start in 2nd gear?
slightly off topic but sometimes i shift from 2nd to 4th and skip 3rd gear... is there anything wrong with that??
06STImulus is offline   Reply With Quote
Old 05-20-2008, 08:56 PM   #32
Fav Mod: Boost gauge
Originally Posted by crf-sti View Post
quick question for the 07 Sti owners out there:
how much taller are your gears then us '04,'05,'06 guys? for example, in my 05 i'm at about 3100-3200k rpm's when at 80mph in 6th, what rpm's are you at when cruising at 80mph?
6th gear is the same 04 and up IIRC.
Old 05-20-2008, 08:57 PM   #33
Should be fine. Might be better as far as saving gas and less wear than starting in second.
Old 05-20-2008, 09:14 PM   #34
Fav Mod: The Newest One!
Never on purpose. I started in 3rd once by accident. Surprised it didnt stall.
Old 05-21-2008, 10:44 AM   #35
Car: 06 Aspen/gold STi
Fav Mod: Whatever I buy next
seems like a good way to wear out your clutch faster than starting in 1st gear.
C.J. is offline   Reply With Quote
Old 05-21-2008, 10:46 AM   #36
perfectly fine and works for increasing gas mileage
GM implemented this in 6 speed Corvettes and V8 Fbody's called "skip shift". If you shifted out of 1st gear before a certain engine speed a plunger inside the tail of the transmission would pop out and guide the shift rod into 4th gear.
Old 05-21-2008, 10:49 AM   #37
If in doubt, flat out
Trader Rating: (23)
I agree.
Forcing it into 1st gear while still moving is an even better way to wear out your synchros. Most people have experienced the fact that once the car is moving, the transmission doesn't like to go into 1st.
Old 05-21-2008, 10:51 AM   #38
Originally Posted by snorky View Post
but forcing it into 1st gear while still moving is an even better way to wear out your synchros. Most people have experienced the fact that once the car is moving, the transmission doesn't like to go into 1st.
Ok I must have misunderstood his post, once the car is rolling I hardly ever go into 1st gear. Starting in 2nd gear from a dead stop is what I understood him to be talking about....and although the car is certainly capable of starting in 2nd and even 3rd gear you have to slip the clutch more than normal and just not worth it IMO.
Old 05-21-2008, 10:51 AM   #39
Trader Rating: (23)
I thought that was an automatic only feature.
Old 05-21-2008, 10:53 AM   #40
Nope, was an annoying feature on the T-56 6speeds, nothing a 25 cent resistor couldn't take care of though
Some of the automatic transmissions like the 4L60e had the option and often did start in 2nd gear though to increase fuel economy.
Old 05-21-2008, 10:56 AM   #41
Trader Rating: (23)
true i edited my post
Old 05-21-2008, 11:01 AM   #42
Trader Rating: (23)
You learn something new every day. I think I would get pissed if I had my hand on or near the shifter getting ready to grab 2nd and the shifter pulled itself into 4th gear.
Old 05-21-2008, 01:05 PM   #43
Ya it's a PITA, you would go to grab 2nd gear and it would be blocked and only let you shift into 4th gear. It actually caused me to almost get rearended a few times so I got rid of it.
Old 05-21-2008, 01:19 PM   #44
Car: 07 STi Blue
Fav Mod: stock :]
did it twice
once to try and the second was accidental... forgot i was in second
bue car is offline   Reply With Quote
Old 06-15-2008, 06:39 PM   #45
Car: Blue 04 STi
Fav Mod: Invidia Turbo Back
I have done a 3rd gear start a few times late at night when im WAY to tried to shift down or throw it in neutral haha... I dont advise doin that tho lol
Dstank is offline   Reply With Quote
