Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > General > Driving Tips & Techniques
Old 04-23-2008, 12:20 PM   #1
Car: Black 07 STI
Default How to drive a 4wd turbo
I just purchased a 07 sti I need some help to maximize my boost. Any tips how to drive?
stiguy5 is offline   Reply With Quote
Old 04-23-2008, 12:24 PM   #2
Car: Black 06 STI
Fav Mod: E-85
Default Re: How to drive a 4wd turbo
i would leave the boost alone...
also should ask the dealer if the ecu map has been changed on it as 07's have been known to blow engines on the stock map (subaru has a few TSB's on it)
Akuma is offline   Reply With Quote
Old 04-23-2008, 05:24 PM   #3
Car: JBP 04 STI
Fav Mod: Stock
very carefully
Yankeeballer13 is offline   Reply With Quote
Old 04-23-2008, 05:28 PM   #4
Fav Mod: BOV and MBC
practice makes perfect
Old 04-23-2008, 05:35 PM   #5
Car: OBP 07 STi
Fav Mod: Ring-Shaped Reinforcement Frame
Your car is gonna start to build boost around 3500rpm. It will taper off around 6500 rpm. Shifting at 6500 is probably the best shift point. Also, try not to lug the engine at all if possible. Don't let it drop below 2000rpm unless there is no load on the engine. Does that about cover it?
USNSTI is online now   Reply With Quote
Old 04-23-2008, 07:09 PM   #6
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
maximize boost...
try WOT
Old 05-04-2008, 12:26 PM   #7
Car: 2006 Subie STi
Fav Mod: Turbo-back exhaust
Send a message via AIM to FastieMagee06
Make sure you launch at 10,000 rpm... Youll have atleast 23 lbs of boost! WOO-HOO! Ignore me...
FastieMagee06 is offline   Reply With Quote
Old 05-05-2008, 04:20 AM   #8
Car: 07 subaru sti
Send a message via Yahoo to moppsquad
i just went to the track yesterday and i got a 13.1 at 104 mph. you can do this to. if you get the stage 2 power package with access port through cobbtuning. and launch at 5500 rpm of the line it takes some practice but man its worth it.
moppsquad is offline   Reply With Quote
Old 05-05-2008, 04:41 AM   #9
Car: 07 STI OBP
Fav Mod: NUR SPEC R, 57maximum t/a,300 shot nitrous, dual carb, ITB,
Originally Posted by evilSTi7 View Post
maximize boost...
try WOT
LMFAO!
Old 05-05-2008, 10:09 AM   #10
I can custom ban you!
maximize your boost? WOT is the way to go then. but I really don't know what you're asking.
just remember, the more you're boosting, the more gas you're using. I know you didn't buy the STI for economical reasons but if you're at all concerned about refilling the gas tank every other day, you'd get a boost gauge and watch how your boost fluctuates as you daily drive.
Old 05-19-2008, 04:45 PM   #11
Car: 04 STI WRB
g00dhum0r is offline   Reply With Quote
