Go Back   IWSTI.com: Subaru STI Forums > Owners' Lounge > Driving Tips & Techniques
Old 03-09-2008, 10:09 AM   #1
Default bucking vs clutch wear
i am new to subies and am just getting used to an 08 sti. The steering is still tight and the car feels like it's on rails (800 miles). my question has to do with a mundane simple issue-getting started. How much clutch slippage is ok when going into first? It seems the clutch is very 'grabby' and there is a brief transition from off to on. I can make a smooth shift but 4 -5 seconds of clutch slip makes me wonder how long will my clutch last. If the slip time is only 1 or 2 secs, the car bucks going in 1st and even a bit going into second. Shifts into 3rd and above are like butter at 1-2 secs. Is this bucking behavior in 1st and second going to wear out the transmission or should i just do 5 second slips in 1st and plan on a new clutch at 30000 miles?
bwana is offline   Reply With Quote
Old 03-09-2008, 10:24 AM   #2
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Default Re: bucking vs clutch wear
It is very "grabby" but don't keep slipping it for 5 seconds. That's way too much slippage. Practice. You'll get better. The only time you should be slipping it that much is in 1st is while backing up or on challenging driveways.
Old 03-09-2008, 11:10 AM   #3
Car: RIP 04 STi
Send a message via AIM to wrxnext
What I do to cope with my "grabby clutch" is to rev it to 1.5K rpm and try and release it quickly but smoothly.... it will usually take about 2-3 seconds.... 2 seconds at best.
It is what it is man, its better to be replacing your clutch at 30K than some drivetrain component....
I bet you have to slip it so long because the clutch is still so new and is not broken in yet. I bet it will get softer/easier to let it out. My exedy stage1 clutch I put in my car was a nightmare at first... but it has gotten a TON better after 3K miles...
Enjoy that 08.... got an 04 here and I love it more everyday
wrxnext is offline   Reply With Quote
Old 03-09-2008, 12:55 PM   #4
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
Is this your first manual? It just takes practice and living with it for a while. Every clutch is different, even among otherwise identical cars. So even if this isn't your first manual, it can take a bit to adjust. You need to find a method that's between the two you're using. Not quite as fast as the one that bogs, but not one that drags out the slipping.
Old 03-11-2008, 12:08 PM   #5
Car: DGM 08 STI
Fav Mod: Driver's school
You might also consider waiting a bit longer before letting the clutch out. It feels like the STI takes forever for its engine speed to come down on a 1 -> 2 shift (and only slightly less so for 2 -> 3), but this too will help make things smoother.
Five second slipping is WAY too much. Practice practice.
e.
encoded is offline   Reply With Quote
Old 03-11-2008, 12:35 PM   #6
Fears smelly diff fluid
Fav Mod: Invidia G200
I like to blip the throttle as I slip the clutch out in first gear on my STI.. seems to be a much smoother transition.
Old 03-14-2008, 09:36 AM   #7
Car: 07 STI UGM
Fav Mod: BOLT ON BOOBIES
+1. thats how I drive my truck also. Little blip and clutch half out gets the car rolling slightly and then clutch all out with gas and your off. Very little slippage if any and no bucking. Of course this is not the way I approach it if I want to accelerate fast of the line, but it's more of a just cruising around "being nice" to the car style of driving.
ConradSTI is offline   Reply With Quote
