Old 08-30-2007, 10:24 PM   #16
Car: 04 subaru sti
Fav Mod: 35r turbo kit
Default Re: Pros and Cons of a light weight flywheel.
sti's usually dont throw a misfire code with a light flywheel unless you have an issue with your management or just something wrong with your motor
will12345 is offline   Reply With Quote
Old 08-30-2007, 10:33 PM   #17
Car: '06 STI
Fav Mod: air freshener!!!
I was told that even a lightweight pulley can throw codes or make erratic issues, esp at low RPMs.
Any truth?
Old 08-31-2007, 12:10 PM   #18
Fav Mod: ohlins w/RCE springs, sz55
Send a message via Skype™ to elirentz
I thought that mine was causing a misfire, but come to find out it was just a bad injector. From what I've read sti's don't have problems with lighter flywheels.
elirentz is offline   Reply With Quote
Old 09-01-2007, 05:39 PM   #19
Car: silver 05 STI
I put a hundred plus miles on my STI with the new clutch/ light weight fly wheel set up today. I stalled the car on the first try, not so much because of the fly wheel but because the clutch pedal engages an inch off the floor! The new clutch is pretty grabby . The car pulls much harder than it used to with the stock weight flywheel . I.m very happy with the end result.
double down is offline   Reply With Quote
Old 09-01-2007, 09:27 PM   #20
Car: '06 STI
DD,
what clutch did you get?
Old 09-02-2007, 04:16 AM   #21
Car: silver 05 STI
mxpop my bad its an ACT clutch and I dont know what flywheel they used.Its half the weight of the stocker thats all I know.
Old 09-02-2007, 09:14 AM   #22
Car: '06 STI
I just had my motor out last week and was gonna put an ACT clutch in at the same time. I didnt cause the stock clutch was still over 50% and I only roadrace, no launches for me, so I saved the $.
My tuner did suggest the ACT clutch if I did one and he said that its a little stiffer but otherwise the same as stock. I think he was intending to reuse my stock pressure plate so if yours is lighter, that's prob what is making the most difficulty driving it.
As for your diff engagement point, I wonder if flushing the clutch fluid would help with that?
Old 09-08-2007, 11:03 AM   #23
On the other hand, the car pulls noticably harder in the lower gears.
I had an ACT clutch and gruppe-s flywheel installed last thursday and I feel like I have lost some torque in the car.. Does anyone else feel this way? I might get up to 100 mph faster than I used to, but I jsut don't feel the pull of the stg 2 I felt before? Is it all in my head? BTW.. the chatter and whine is kinda annoying... I almost wish I had resurfaced the stock one..
pooster.online is offline   Reply With Quote
Old 09-08-2007, 11:24 AM   #24
Fav Mod: when it's not blown up
My STI never threw a misfire code with a lightweight flywheel (ACT Prolite).
Old 09-08-2007, 12:10 PM   #25
GT R US
it is not in your head. it is the predictable effect of losing the rotational mass of the oem fw.
Old 09-10-2007, 11:08 PM   #26
also discovered I don't hit max boost of 20 psi like I used to with the stock flywheel. man... lightweight flywheel sucks.
Old 09-11-2007, 07:45 AM   #27
Fav Mod: TBE
From my understanding, putting a lighter flywheel on throws off the balance of your rotating mass and lessens the life of the engine. Has anyone else heard of that?
Old 09-11-2007, 08:13 AM   #28
Trader Rating: (43)
Send a message via AIM to Z1 Performance
only if Helen Keller made the aftermarket flywheel - the ACT ones are balanced even better than the stock one is
Z1 Performance is offline   Reply With Quote
Old 09-11-2007, 10:01 PM   #29
Fav Mod: Starving my STI
Trader Rating: (12)
What boost are u hitting then? And is this even after a retune? In all gears?
Old 09-12-2007, 10:30 AM   #30
Fav Mod: remap
i didnt notice much difference after installing ACT prolite
what i did notice is that i need to rev to 5500 now to launch the car otherwise it just bogggs down even with LC !!
rasheedn is offline   Reply With Quote
