| | #46 | |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,780
IWSTI Addict since: Dec 2004 Trader Rating: (7) | Quote:
what are you comparing it to? Cruising on hwy vs staying in 3rd going down hill? This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #48 |
| Senior STI Driver Car: 04 subaru WRX STi Fav Mod: KEY!S steering wheel Location: so cal Posts: 380
IWSTI Addict since: Dec 2005 Trader Rating: (8) | all being said i agree with what the clap has to say. but as for my own beliefs, i believe that brakes are a much less costly thing to replace and submit to daily 'abuse' than the motor EVER is. not to say that day to day driving is anything close to abuse for these cars. downshifting and engine braking when thinking youre going to accelerate soon again like when in intermittent traffic is something i do but to downshift to slow down instead of just hittin the middle pedal a little harder? its a no brainer to me. in any sign of traffic stopping i kick it out of gear and hit the brakes... saves gas too, all that downshifting and high rpms to slow down is also wasting that premium(crap) gas that's 3.50 per gallon these days... i dunno take from it what you will it's only my opinion |
| | #49 |
| Professional STI Racer Car: 2006 Aspen White STi Location: Cackramento, CA Posts: 843
IWSTI Addict since: Jul 2006 Trader Rating: (0) | if there was a stop sign coming up and no car infront of me or behind me and im in 4th gear going 35MPH i put it in N and let it cost and break little by little so you don't wear out the break pads that much. i don't do that fancy downshift stuff. okay..so my right turn is coming up and im in 4th gear again going 35MPH and i break while still in 4th and slow down to 10MPH and i downshift to 2nd to make that right turn... i don't need to rev match or nohting like that right?? |
| | #50 |
| STI Driver Car: 06' Aspen White STI Fav Mod: Girlfriend Location: SOCAL Posts: 218
IWSTI Addict since: Mar 2006 Trader Rating: (0) | I slow down, downshift into a lower gear (such as second), rev match, then take off when I exit the turn. Of course this is down pretty quick. The best way is to do heel-and-toe, which makes things way more fun because you can do it in a sequence. These are just lil things to learn to make driving your manual car more fun. |
| | #51 | |
| Spec C Club
Car: 04' WRB STi Fav Mod: TBE Location: Allentown, PA Posts: 1,647
IWSTI Addict since: Sep 2006 Trader Rating: (1) | Quote:
It seems like you're dead set against engine braking tho. As far as the comment on either being on the brakes or gas on the track, have you ever seen the video of Gary Sheehan driving where you can see his feet. He's heel toeing and revmatching and braking into almost every corner. I'm no race driver and I don't claim to be, but I do know that engine braking should be used to assist in braking, and also to get yourself into the right gear to exit a corner. When just driving on the street, it is still useful to assist in braking either just to slow down or to come to a complete stop. Also like 2slow said you can use it to hold a gear on a hill. I do agree with you on the efficiency of using the brakes versus using the engine to brake. Your brakes will stop you much faster and they are cheaper to replace if they wear, but it is pretty useful to engine brake to assist in braking as well. | |
| | #52 |
| Grassroots STI Racer Car: 05 WRB STi Fav Mod: Pro Tune Location: Misery (MO) Posts: 565
IWSTI Addict since: Oct 2005 Trader Rating: (0) | This thread is all messed up. Why would downshifting and engine breaking have any wear on the clutch? I engine break, as well as use my breaks at almost every stop I come too. Lets say I'm crusing through town at 40mph in 4th gear. I see cars up ahead stopped at a sign/light. I downshift to 3rd and start lightly using my breaks while leaving my car in gear until the RPM's drop enough to where I need to put it in neutral and then use the brakes the rest of the way. Or when I'm on the highway cruising at 80mph and get off, I slow down a little bit in 6th until my rpms drop, then downshift to 4th let out and slow down more, then maybe one more downshift to 2nd and do the same. Why would you want to use just your brakes and wear you brake pads down faster? I have 52k miles on my car and I'm still running the original brake pads. |
| | #53 | |
| Wheel33tist Whore
hmm, remind me not to buy your car when you sell. | |
| | #54 | |
| Wheel33tist Whore
it's heavy on brakes, downshifting through the gears (without letting the clutch out), then rev match for the corner, then back on the gas. when i said only on gas or brake i was referring to when you're IN GEAR (not in neutral and clutch let out). oh well, dead horse here, if you guys are ok with adding extra wear to your drivetrain to save your brake pads more power to you. | |
| | #55 | |
IWSTI Addict since: Oct 2005 Trader Rating: (0) | Quote:
| | #56 | |
| Wheel33tist Whore
then multiply that by 40 times per month, then 11 months (assuming you get a month off). hey, i'm not the one who gets to replace the clutch earlier then necessary. I beat the **** out of my clutch enough with Autox that i'd rather be nice to it on the street. | |
| | #58 |
IWSTI Addict since: Oct 2005 Trader Rating: (0) | Back to the original question, Will engine braking hurt my car answer, NO. And if you downshift properly, you will not put much stress on your clutch |
| | #59 | |
| Wheel33tist Whore
and depress the clutch when it's time to start clicking down through the gears, if i forsee the need to be In gear to either accelerate or maneuver i will get in gear, other wise the clutch is in, and the shifter is in the correct gear so if need be all i need to do is blip the throttle and let out the clutch to acellerate. I only actually shift into neutral and let out the clutch when I know for sure i'll be stoping. I never actually let out the clutch to be IN GEAR unless I will need to, but at least the gear lever has the correct gear selected in the event i do need to do exactly that. | |
| | #60 | |
| Wheel33tist Whore
but as you said before your way keeps your $200 brake pads for longer This ad is not endorsed by this member. Please register or login to hide this ad. | |
