| Amateur STI Driver Car: white 2006 wrx sti Fav Mod: idk have a few love them all Location: santa clarita Posts: 32
IWSTI Addict since: Dec 2006 Trader Rating: (0) | hey guys in my car 2nd 3rd 4th 5th gear slip when i step on it at 3000 rpm when the turbo spools but idk if it is the clutch because it only does it sometims so can you guys please help if you have heard of this before thanks, its only after 3000 rpm tho. ryan This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #4 |
| dances with roads | There is only one thing connecting the engine to the transmission/drivetrain: the clutch. If you are experiencing slippage between the two, it's the clutch. |
| | #6 | |
| S204 Racer | Quote:
| | #7 |
IWSTI Addict since: Dec 2006 Trader Rating: (0) | ok thanks i kinda thought it might be the tranny because i thought after 3thousand rpm the clutch didnt have to do with it. and is that covered under warranty? |
| | #8 | |
| Spec C Club Car: 08 STi, SSM Location: Edmonds Washington Posts: 1,428
IWSTI Addict since: Dec 2005 Trader Rating: (0) | Quote:
Read up: http://auto.howstuffworks.com/clutch.htm The clutch is usually considered a wear item like brake pads so unless they fail unusually early or due to an incorrect installation from the factory, they are not always warrantied. Check the paperwork that came with your car, more specifically the warranty booklet to see what's covered and call your service manager to ask if the clutch replacement is covered. | |
| | #9 |
| Spec C Club | Replace your clutch quickly. You may have to do the flywheel if you've been driving this way for a while. I had my clutch replaced on Sunday, '04 with 37k miles. Flywheel had to be replaced due to some blueing and heat cracks. |
| | #10 |
| S204 Racer
Car: 1998 Impreza GF8 Location: Miami, Fl. Posts: 2,587
IWSTI Addict since: Aug 2005 Trader Rating: (3) | Clutch replacement coming up! This ad is not endorsed by this member. Please register or login to hide this ad. |
