Old 05-10-2007, 04:59 PM   #1
Car: AP 2005 STI
Default Clicking while decelerating and accelerating, not suspension
Update for anyone who cares:
I ended up having a cracked drive shaft by the rear end connection. Liberty Subaru found it and replaced under warranty.
I don't think it's the CV's on the axel, but I haven't been able to pin point where the noise is comming from. The wife says it's on the drivers side, I think it's comming from the center, either way it's in the rear somewhere by the rear seat or slightly behind it. This happens when I stop accelerating, but not instantly, it does not seem to be caused by instant lift. It takes about 1/2sec to 1sec to click. If I ease back to the throttle it will click again. I do not feel anything, I just hear it. Any ideas? I am probably going to go to the dealer eventualy because I believe this will be covered, but I would like to know what it could be so they do not BS me. Thanks.
repmud is offline   Reply With Quote
Old 05-11-2007, 11:01 AM   #2
Car: 05 STi OBP
Fav Mod: Data Acq System
Default Re: Clicking while decelerating and accelerating, not suspension
I freaked out about this when I got my car. I forgot which thread here somebody explained it but it is because of our rear diff. Nothing is wrong with your car. The diff wears a bit/breaks in a bit and you have a bit of slop of some sort and that is what you hear.
I have had this noise for over 30k now and I race and daily drive my car without any issues so far outside of plenty noises I never heard before
Anyhow, search for a thread starting with knocking in the rear and somebody explains how the 1.5 lim slip diff's do that.
MGizzle is offline   Reply With Quote
Old 05-11-2007, 11:05 AM   #3
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Same here^
flatthump is online now   Reply With Quote
Old 05-11-2007, 11:12 AM   #4
Car: 2006 STI BLUE
Fav Mod: Fp20g and protune
funnie thing is i was going to post the same thing .. Say your in second gear and all of a sudden u lift u will get a click hmm i guess it happens to us all it sound like it
Old 05-11-2007, 11:14 AM   #5
Car: 06 OBP STi
Normal...no worries. We all have it...I do too! Worried me at first as well...but sought info and we are all ok.
Kind Regards,
Ryan
r12rex is offline   Reply With Quote
Old 05-11-2007, 11:18 AM   #6
Fav Mod: coilovers & www.hpdedriver.com
Send a message via AIM to SubyFi
Try and retighten the rear axle nuts to 140 ft lbs. with a 32mm socket.
SubyFi is offline   Reply With Quote
Old 05-12-2007, 05:13 PM   #7
Car: AP 2005 STI
Thanks guys...I was trying to think of another word for clicking to search for, never thought of knocking...
Old 05-12-2007, 05:33 PM   #8
Fav Mod: ACPT driveshaft
Yeah, the STI makes a racket after getting a few miles on it. My brake pads slap around in the back, my diff clicks and clacks, no shortage of interior rattles. It's character.
HarlanPepper is offline   Reply With Quote
Old 05-13-2007, 04:50 AM   #9
STI Guru
Fav Mod: grip.
long story short... i took my car to subaru with this noise because it was pissing me off... the replaced my rear diff at roughly 8000 miles because they couldnt figure it out.
Old 05-13-2007, 09:49 AM   #10
Congrats on that. I went to a two different dealerships and they couldn't figure it out either... but I didn't get a new diff out of it
Old 05-15-2007, 05:48 AM   #11
Car: 05 STi OBP
The dealers crack me up. 95% of them have no idea about cars and common sense mechanical abilities but they do know how to get money from Subaru.
Old 05-24-2007, 07:58 PM   #12
Car: '07 STI WRB
Don't knock em on a daily basis if your good we see stuff you could never imagine. The knocking is a series of issues; first the rear axles need to be backed out the hub slightly, then lubed, slid back into place and retorqued with a new nut. Second if it only happens while accel-decel and vise versa then the next step is the axles being toasted, inner cv joints get toasted pretty easily but on different levels of damage, and finally buy yourself a ned ring and pinion. Have fun but burn the clutch not the drivetrain.
ScbiSnx is offline   Reply With Quote
Old 10-20-2007, 04:51 PM   #13
Car: AP 2005 STI
bump for problem solved.
Old 10-20-2007, 09:20 PM   #14
Car: 06 CGM/silver STI
Fav Mod: DIY modding
Drivetrain clunk on decel/engine braking...
FleaDog is offline   Reply With Quote
Old 10-22-2007, 06:48 AM   #15
Car: AP 2005 STI
I guess I should have wrote that I edited the 1st post and added the solution to my problem. It is in bold.
