Old 04-12-2007, 07:19 PM   #1
Fav Mod: BOV and MBC
IWSTI Addict since: Mar 2005
Default Downshift into 4th....Grind???
I'm cruisng down the parway the other day and about to get off my exit, so I downshift into 4th gear and it grinds a bit. I thought maybe I didnt have the clutch in all the way so I forget about it. Same things happens today and I was sure that the clutch was to the ground. It wasnt as bad but it had a notchy feel and made a quick click. What is this? Syncros going. Id figured 2nd would be the first to go if anything. Maybe bushing? I dunno. Ideas?
Old 04-12-2007, 07:23 PM   #2
Car: 04 Sti
IWSTI Addict since: Sep 2006
my 4th sometimes grinds, i have an 04
bigJP is offline   Reply With Quote
Old 04-13-2007, 09:36 AM   #3
Car: 07 STI BABY!!!
Fav Mod: Driving School
IWSTI Addict since: Oct 2006
Trader Rating: (15)
Send a message via AIM to Pearson II
How many miles are on your car? Have you ever changed the fluid?
Pearson II is offline   Reply With Quote
Old 04-13-2007, 08:46 PM   #4
30K miles, fluid change 2K ago. Did it again today. It seems like it does it grinds when I downshift from 60+ MPH. Otherwise it wont.
Old 04-13-2007, 08:53 PM   #5
Car: 05 STi, 04 M3, 90 Sp
Fav Mod: Clear bra
Likely a synchro issue, you should try to get it covered under warranty.
I had to get this taken care of at about 17k miles. Same gear too.
smurfm3 is offline   Reply With Quote
Old 04-13-2007, 11:52 PM   #6
IWSTI Addict since: Jul 2006
I just got the same stuff on mine STi 04. It was grinding going from 5th to 4th at higher speeds. I though it was synchross, but when I brought it to dealer, they said it was 4th gears going bad and will have to be replaced (after checking my car of course). Car has 39K miles and it is covered under manufactured warranty.
STLDude is offline   Reply With Quote
Old 04-14-2007, 12:31 PM   #7
Car: 07 STI BABY!!!
Trader Rating: (15)
Sounds like taking this one to the dealer is the way to go. On a side note what fluid did you use?
Old 04-14-2007, 08:47 PM   #8
Unfortunately, I dont think the dealer will be happy with the Stage 2, FMIC, meth
Old 04-14-2007, 10:04 PM   #9
Car: 06 WRB STI
Fav Mod: Title in hand?
IWSTI Addict since: Dec 2006
WHOOPS!
minorthreats is offline   Reply With Quote
Old 04-15-2007, 10:45 AM   #10
Car: 07 STI BABY!!!
Trader Rating: (15)
Yeah...me thinks you might have a problem getting the dealer to do anything.
Old 04-15-2007, 10:49 AM   #11
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
try double clutching and read the turninconcepts thread about their tranny.
Old 04-15-2007, 05:50 PM   #12
i know i should search, but could you give me a quick definition of double clutching. Is it clutch down, pull out of gear, clutch up, clutch down, downshift, clutch up?
Old 04-15-2007, 05:55 PM   #13
Car: RIP 02 WRX
IWSTI Addict since: Dec 2005
agreed.
Old 04-15-2007, 05:55 PM   #14
Car: RIP 02 WRX
Yes, add a "revmatch" in between the bolded areas.
Old 04-15-2007, 06:37 PM   #15
linky to tic tranny thread?
