Old 04-11-2007, 09:39 AM   #1
Banned
Car: 05 OBP STi
IWSTI Addict since: Aug 2005
Default Default DCCD Setting
When the car's power is cycled off and on, the DCCD resets to Auto.
Is there are way to force the DCCD into Open mode all the time... besides pressing the button everytime.
Kurokaze is offline   Reply With Quote
Old 04-11-2007, 09:40 AM   #2
Super Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
You would have to reprogram the DCCD computer. IDK of any software to do this, but with enough money/time/enginuity anything is possible.
Old 04-11-2007, 10:08 AM   #3
wdb
dances with roads
IWSTI Addict since: Apr 2005
There is a switch, operated by raising the handbrake lever, which sets the DCCD to 'open' (possibly really, really open and not nannied by the computer at all). You could wire your own switch in parallel with it.
Old 04-11-2007, 10:33 AM   #4
Car: 05 obp/gold
IWSTI Addict since: May 2005
^^^^That will work, or same thing on the rear diff temp sensor would work as well. Not sure why this would be desired, though.
gregsachs is offline   Reply With Quote
Old 04-11-2007, 10:49 AM   #5
Banned
Car: 05 OBP STi
I noticed the car binds slightly around slow sharp corners on Auto, but when the DCCD is set to full open... the bottom circle... this doesn't happen and the car feels more predictable around every corner. A preference.
Old 04-11-2007, 02:14 PM   #6
IWSTI Addict since: Nov 2005
you could probably wire something up in parralell to the auto/manual switch to pulse (close the circuit and then go back open again) on startup. then you could just leave the wheel in full open. that way you'd still have the ability to put it in auto if you want, and adjust it manually via the wheel.
KrazyKarl is offline   Reply With Quote
Old 04-12-2007, 01:54 PM   #7
Car: 05 obp/gold
OK, note that "open" _may_ not actually be the same as having the diff in open. Easiest least invasive way of doing this would be a switch in parallel with the e-brake switch, as the diff will go fully open on e-brake, or a switch in series on the diff temp sensor. Both of these are failsafe modes that override the driver setting and go to an open condition. This may be a different state than the driver preference "open" setting from the dial. (especially the temp sensor method).
