Old 03-31-2007, 08:11 PM   #16
IWSTI Addict since: Feb 2007
Originally Posted by Stik11
ickevin does the noise get faster when u increase speed? and when u slow down the noise slows down also and completely disapears when u are stopped? does 5th or 6th gear still produce the same noise but a little more clearer? if any of these applies i think your problem might be the reverse lockout cable rubbing on the spinning drivetrain... easiest way to confirm this is to take the shift boot off completely go for a rid put it in one of the gears that produces the noise and take your finger and pull up the reverse lockout cable from where it goes down into the rubber boot and down to the bottom of the car. if thats the case then u need some zip ties to fix this ... hope this helps .. if u need me to explain better pm me
while installing the short shifter, we had problem with getting the reverse lock perfect, took us lil time to figure it out but eventually, we figured it out. i saw that reverse lock cable is hanging down and that huge tranny bar thing that turns might be scraping it, maybe that was the problem all along? and yes, this happens when i let go of the gas pedal and decelerating. no noise associated with accelerating.
ickeviniskool is offline   Reply With Quote
Old 04-01-2007, 06:02 AM   #17
Car: '05 PSM STi
IWSTI Addict since: Aug 2004
i really dont think this is any of the gears grinding i know with changing the bushings u have an increase in the tranny driveshaft noise .. but i really do think its the reverse lockout cable ... take the boot out and take the car for a spin while in gear pull the reverse lockout cable up from under the shifter where it goes through the hole in the rubber boot down at the bottom (the reverse lockout ring being pulled up may not help) .. i'm almost positive this is whats going on because i ran into the same prob after doing my cobb double adjustable short shifter
Stik11 is offline   Reply With Quote
Old 04-01-2007, 09:44 AM   #18
Muller Chevrolet
Fav Mod: beastly fenders
IWSTI Addict since: Oct 2004
it says in the intructions to make sure the cable isn't touching the "driveshaft" boy learn your car.
zip tie it up.
Old 04-01-2007, 01:58 PM   #19
zip tie it up.
i do not know much about the car, that is why i took it to a mechanic at the first place.
i am trying to learn how to fix it so i came here to learn how to, thx for trying to help but i don't think attitude is nessecary.
i really do appriciate the time and effort you guys are putting into to help though
Old 04-01-2007, 02:39 PM   #20
Muller Chevrolet
wasn't giving you attitude, but you shouldn't tackle something you know nothing about even if someone is doing it for you because you can't be certain they know wtf they're doing or if they half ass.
Old 04-01-2007, 03:50 PM   #21
Car: '05 PSM STi
any update on whats going on did u try it?
Old 04-02-2007, 09:35 PM   #22
i jacked up and zip died the reverse lock cable. it seems the noise went down when i pulled up the cable (before zip tying it)
i still do here some grinding noise but not as much as before, i suppose that is the gear rotating?
the noise seldom catches my attension now, unlike before, i have to actually listen carefully while driving.
is there anyway to reduce the grinding noise further?
Old 04-07-2007, 04:35 AM   #23
Car: '05 PSM STi
what did u zip tie it to? the shifter right?
