| Spec C Club Car: '05 CGM Fav Mod: HPDEs Location: Omaha, Nebraska Posts: 1,263
IWSTI Addict since: May 2006 Trader Rating: (3) | I have a friend that asked me whether the '07 transmission with its longer 2nd, 3rd and 4th gears could be swapped into an '05 STi. I didn't have an answer for him, but I thought maybe this group might? Is this a direct plug and play swap? Thanks! Gary This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
IWSTI Addict since: May 2006 Trader Rating: (3) | I had researched that previous thread this morning. It is in fact one to which I had contributed. But nowhere in that thread did I find any discussion of whether or not the actual transmissions could be swapped. There a very short discussion of swapping gear sets. But no discussion of switching the whole unit. Gary |
| | #4 |
| The Next Petter Solberg Car: 06 WRX STI Fav Mod: Front license plate delete Location: San Diego Posts: 955
IWSTI Addict since: Aug 2006 Trader Rating: (2) | I am sure the transmissions can be swapped but as far purchasing one from the factory I have heard they are anywhere from 8-11K . The swap should be plug-in-play to answer your question. |
| | #5 | |
| Super Moderator | Quote:
EDIT: They are VERY expensive from the factory though, either buy a gearset or buy a wrecked car trans. Also, seeing as the 05 is a 35/65 center diff gearing and the 06+ is 41/59 you may need 07 gears for your rear diff as it would change your final drive ratio. | |
| | #8 | |
| | #9 |
| Wheel33tist Whore
Car: Aspen White GDF-D Fav Mod: Pastelito Racing / SFSOC Location: 0R!4ND0 Posts: 21,781
IWSTI Addict since: Dec 2004 Trader Rating: (7) | if you were to do it, you'd want to do the full driveline (tranny and rear diff). unless you're willing to open up the 6 speed :eek: which requires alot of work to get back together btw. |
| | #10 | |
| STI Master Car: 04 JVP STi Fav Mod: Blitz NUR Spec R Location: B.F.E, Texas Posts: 7,985
IWSTI Addict since: Apr 2004 Trader Rating: (3) | Quote:
| | #11 | |
| Wheel33tist Whore
IWSTI Addict since: Dec 2004 Trader Rating: (7) | Quote:
![]() i don't plan on tearing apart a 6-speed any time soon | |
| | #14 |
| Junior STI Driver Car: 00 RSTI Fav Mod: STI swap Location: Michigan Posts: 125
IWSTI Addict since: Jun 2006 Trader Rating: (0) | Id agree that the DCCD would need to be swapped as mentioned, i believe that with the yaw sensors, there is also a steering angle input as well. i could see this being a limiting factor for a daily driver. |
| | #15 |
IWSTI Addict since: May 2006 Trader Rating: (3) | Thanks for the input. I'll pass this along to my buddy. Gary This ad is not endorsed by this member. Please register or login to hide this ad. |
