| Lurker | I sound like a noob but in what position should I set the DCCD to get a 50/50 slpit of torque and traction? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #4 |
| Spec C Club Car: Motorcycles Fav Mod: Student Location: Western Washington Posts: 1,929
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Can't be done, DCCD does not change torque distribution. If you want no slip between front and back wheels, which is probably what you're looking for, just set it to full lock. |
| | #9 |
| Amateur STI Driver Car: Silver 04 WRX STi Fav Mod: tire dressing Location: ny Posts: 8
IWSTI Addict since: Mar 2004 Trader Rating: (0) | I found this info :http://wallace.as.arizona.edu/~cgrop.../DCCD_FAQ.html :wink: read it a few times, it helps |
| | #11 |
| Senior STI Driver Car: black 04 wrx sti Fav Mod: none Location: seattle Posts: 377
IWSTI Addict since: Sep 2003 Trader Rating: (0) | ok so from reading this article im not sure WHEN to use open or lock...this only describes how it works. Im assuming you leave it auto for normal driving conditions and lock it under limited traction condidtions? lemme know if im wrong, im a bit confused. |
| | #12 |
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Yea, pretty much. I'm not sure what's best for the track, but basically leave it open/auto most of the time, and when it gets slippery, turn up the lock. Full lock should be saved for gravel, dirt, or snow.... it's not good for rain, you still have too much traction. (based on my experiences w/ a 4x4 truck....) |
| | #13 |
| Spec C Club Fav Mod: Stealth mode Location: Eugene, Oregon Posts: 1,154
IWSTI Addict since: Nov 2003 Trader Rating: (2) | I only mess with it now if I'm trying to get maximum acceleration on a slick surface. The rest of the time I leave it in auto, and that seems to work very well for autocross as well. |
| | #14 |
| Spiteful Old Codger | I think most of the confusion surrounding the F/R torque split stems from the fact that people don't realize that the DCCD clutch distributes torque in proportion to slip - just like a common LSD. Otherwise, the F/R split is simply a funtion of the DCCD's gearing (35/65). At least that's my understanding. |
| | #15 |
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Yea, that's a pretty good way to explain it. This ad is not endorsed by this member. Please register or login to hide this ad. |
