Old 03-29-2004, 01:27 PM   #16
Spiteful Old Codger
IWSTI Addict since: Jul 2003
Default More new stuff and Fixed link. Route planning/Road software.
I just look it as a split shaft with an open differential geared to 35/65. In addition to the differential, the shaft is broken by a plate-clutch LSD up the shaft some distance from the differential. The LSD happens to have the ability to be disengaged from the shaft.
With all this in mind, it's obvious that the shaft sections are always geared in a 35/65 proportion. The way that the torque split can vary from 35/65 is if the LSD is engaged, and one of the axles slips. Then torque is distributed according to traction up to the maximum allowed by the clutch. If there's no slip the split is always 35/65. This is exactly the same way an LSD would behave in a front drive transaxle.
Now, to this you have to add a few concepts: The LSD has the capacity to be controlled automatically by an ECU, the LSD can also be controlled manually and it is continuously variable from no engagement up to maximum engagement, and of course there are also the LSD's on the front and rear axles, which are also potentially ECU-controlled. Finally, engaging the e-brake temporarily disengages the differential.
It's pretty complicated if you try to grasp it all at once, but much more accessible if you take it one step at a time.
Now, the question is, how the Hell do I actually use this thing?
Old 03-29-2004, 01:44 PM   #17
Fav Mod: Track Time
IWSTI Addict since: Jan 2004
Ya, what he said
WE_R_ND is offline   Reply With Quote
Old 03-29-2004, 05:41 PM   #18
Car: Motorcycles
Fav Mod: Student
IWSTI Addict since: Oct 2003
If you're racing, just experiment to see what's best, otherwise,
Open/Auto normally, and Lock on loose surfaces.
bitabur is offline   Reply With Quote
Old 03-29-2004, 06:01 PM   #19
Spiteful Old Codger
Default Just got an STI from A and T subaru (great service/price)
That's pretty much where I am.
"Lock" is definitely the bees' knees on loose stuff... and a hoot in a vacant parking lot.
I need to mess with "auto" a bunch more before I can say anything about how it compares to setting the clutch for dry tarmac.
Old 06-04-2005, 01:14 PM   #20
Car: working out, studyin
Fav Mod: Gavin My Siberian Husky
IWSTI Addict since: Apr 2005
Send a message via AIM to ayanami22
did a little searching and still cant find how to utilize the dccd vey well, or a good explanation of how/when to use it...any help thanks in advance
ayanami22 is offline   Reply With Quote
