| Junior STI Driver Car: 04 WRX STi Fav Mod: Whiteline Everything Location: Central Oregon Posts: 82
IWSTI Addict since: Sep 2006 Trader Rating: (2) | Do these things work well? or can they damage seals with the reverse suction on the crankcase? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 | |
| Junior STI Driver | Quote:
Works well on many other cars. Does not extract all oil from our engine as apparently baffle plate in sum prevent the extractor tube to go all the way to bottom of oil pan. You still need to pull the filter form underside. A Fumotive valve helps. | |
| | #4 | |
Works well on many other cars. Does not extract all oil from our engine as apparently baffle plate in sum prevent the extractor tube to go all the way to bottom of oil pan. You still need to pull the filter from underside. A Fumotive valve helps. This ad is not endorsed by this member. Please register or login to hide this ad. | |
