Old 02-10-2007, 12:46 PM   #1
Car: 06 STi
Fav Mod: Pro Tune
IWSTI Addict since: Dec 2005
Default Why is my DCCD light blinking green?
Ok, all I did was change out my steering rack bushings yesterday. Afterward when I got into the car I noticed a green light blinking. Those indicator lights that go vertically on the instrument cluster that change color from green to orange to red I think. They change when you put the DCCD in manual mode and adjust manually. Well the green light at the bottom of the cluster(which is green) is continously blinking. I checked underneath today and couldn't see any problems. Anyone know what might have happened? Should I just take it to the dealer?
jtrafidlo is offline   Reply With Quote
Old 02-10-2007, 12:57 PM   #2
Shamwow Vince is my hero
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
can you pull a CEL code?
try resetting your ecu. if it comes back, i'd see the dealer.
Old 02-10-2007, 12:58 PM   #3
Knows that game.
Fav Mod: Crawford, and a nice flat-6.
IWSTI Addict since: Jun 2006
its a code, i guess like a check engine light. go to autozone plug in a obd scanner. long blinks are 1.2 sec. (signifies incriments of 10) and short ones are .2 sec (signifies incriments of 1)
ex. long, long, short, short, short would be code 23
ACHAHockey is offline   Reply With Quote
Old 02-10-2007, 12:59 PM   #4
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
he has an ap, so he should be able to use that to pull the code.
Old 02-10-2007, 02:44 PM   #5
Car: 06 STi
Fav Mod: Pro Tune
I don't think it's a check engine light. It's the bottom arrow that blinks green. When it's a CEL isn't it the check engine light that blinks? It doesn't blink in any special pattern, it's like a turn signal blink. I don't know. The AP says there ar no codes.
Old 02-10-2007, 03:06 PM   #6
Car: '08 BMW 135i
IWSTI Addict since: May 2005
Trader Rating: (13)
Hmmm... I am interested in what this means as well.
MadMan77 is offline   Reply With Quote
Old 02-10-2007, 03:10 PM   #7
Car: 06 STI
IWSTI Addict since: May 2006
Are you referring to the green circle '0' which normally indicates 'open' when the DCCD is manual mode. The subaru manual indicates that this light will flash if there is a problem with the DCCD.
Deuce Cam is offline   Reply With Quote
Old 02-11-2007, 09:04 AM   #8
Car: 06 STi
Fav Mod: Pro Tune
I guess it's time to call subaru
Old 02-11-2007, 09:59 AM   #9
Car: 05 obp/gold
on the 04, the dccd trouble code could be pulled by the following procedure:
engage parking brake
turn ignition to on
set dccd to min
fully depress throttle
turn dccd dial fully to max, then back to min. repeat this 10 times
It will flash 2x/sec if there is no trouble code
If there is a trouble code, a 1.2 s flash indicates a 10 digit, and a .2s flash is a 1 digit. So 1.2, 1.2, .2, .2 would be a 22
diagnostic procedure:
1: engage parking brake
2: set dial to min
3: start engine
4: set dial to max
5: release parking brake
6: set dial to min
7: engage parking brake
8: repeat 4-7 twice in 30 seconds
(will now get a trouble code display)
9: operate parking brake
10: operate brake pedal
11: operate manual mode
12: operate dial and set to max, wait 3 seconds
13: drive above 10mph for at least 5 seconds and check the indicator status light
At this point if the system is happy the next ignition cycle will clear the dccd trouble code
There are only 7 dccd codes, 11, 12, 13,14, 21, 22, 23. Rear diff sensor is not a trouble code, just an override condition that will clear as soon as temp is ok.
gregsachs is offline   Reply With Quote
Old 02-11-2007, 06:04 PM   #10
Car: 04 STi-sold it
IWSTI Addict since: Nov 2005
Send a message via AIM to scoob
I think that blinking light might have to do with more than your DCCD. I had a short in my rear O2 sensor 2 weeks ago and it blew a fuse. The bottom light on the DCCD started blinking just as you described. Replaced the fuse & the DCCD light stopped blinking. Perhaps something shorted out?
scoob is offline   Reply With Quote
Old 02-12-2007, 06:32 AM   #11
Car: 06 STi
Fav Mod: Pro Tune
Thanks, I'll think I'll check the fuses first!
Old 04-14-2007, 06:09 PM   #12
Car: 06 White/Gold STi
IWSTI Addict since: Feb 2006
any updates on this? same thing happened to me today, just curious about possible solutions before I head to the dealer this week
gabe is offline   Reply With Quote
Old 04-14-2007, 06:20 PM   #13
Fav Mod: Snow
IWSTI Addict since: Sep 2006
I can just see it now.
"Due to your aftermarket exhaust and ECU map, your warrenty is void"
Old 04-15-2007, 01:19 PM   #14
Car: 06 STi
Fav Mod: Pro Tune
They told me it was a steering position sensor and replaced it without question
Old 05-20-2007, 07:32 PM   #15
Car: 2007 SWP STI
IWSTI Addict since: Nov 2006
Default Re: Why is my DCCD light blinking green?
I just did the WL steering rack bushing and am now getting this blinking DCCD light along with an airbag light (?!?). This has been a horrible install--two stripped holes on the steering rack and now this. This has consumed most of my weekend.
I've been searching on a few forums looking for this--can't seem to get a definitive answer...anyone have any ideas? Going to try and get an appointment with the dealer tomorrow.
Edit: re-flashed back to stock ROM (from gabe's Stg0 R1) and am now getting a CEL along with the above mentioned lights. Car's at the dealer right now. $95 diagnosis fee (free if under warranty). Don't think it's related to the R1 ROM, but I wanted to post for comments.
Edit2: Got word back from the dealer...bad clock spring...caused by me. $450 parts/labor. CEL was from me leaving the green connectors in after re-flashing. I feel like a dumbazz for both issues.
jsmithjr732 is offline   Reply With Quote
