Old 02-05-2007, 04:54 PM   #1
Default Popping from left rear hub/axle/?
Today I noticed that whenever I start moving in either direction, either from a stop or from rolling in the opposite direction, I get a pop from the left rear hub area. I'm fairly new to the AWD stuff (and anything with CV joints ), so I'm not sure what I'm hearing. Here is a rundown of what I've determined:
1. Happens only once, then doesn't happen again until a change in wheel rotation direction.
2. Forward or reverse, same sound either way.
3. Setting the e-brake and loading up the driveline causes the pop, but it takes a fair amount of force before it happens (it's not slop).
4. Only happens on the left side, right side is quiet.
5. Turning the wheels by hand while feeling the axle, it appears there is zero slop until you get internal to the differential, where there is a small amount.
6. The noise can be reproduced by hand with the car in the air by turning the wheel back and forth fairly hard.
My first thought was CV joint. Honestly, though, I'm not at all familiar with the failure symptoms for a CV joint. The other thought I had was perhaps something to do with the e-brake. Couple of days ago when I was doing brake pads I noticed that the left wheel was locked nicely by the e-brake, the right one was not. Since then I have not reproduced that particular behavior.
Thoughts? Surely there have been a number of failed CV joints in the time the STI has been out, so I'm hoping someone can tell me whether or not it sounds right.
Tomorrow I think I'll take it to the dealer, hopefully they won't deny coverage. I'm stage 2, but I don't abuse the car (no launches, never drag raced), and it seems unlikely something I did would break a CV joint.
Dave
Old 02-05-2007, 05:16 PM   #2
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
Kinda sounds like CV joints, but its a little harder to diagnose when you cant turn the wheel. I'd let the dealer screw with it...
Old 02-05-2007, 07:20 PM   #3
Looks like that's about my only option. I hate letting the dealer touch my car .
I did some more research and my bet is inner CV joint, as that seems to be what the symptoms indicate. Grrr. I'd fix it myself except the axle assembly seems a bit pricey...
Old 02-26-2008, 08:32 AM   #4
Default Re: Popping from left rear hub/axle/?
Did you ever find out what this was? I also noticed my rear passenger wheel is not locked when the parking brake is engaged while the driver's rear is locked.
bobbybouchet is offline   Reply With Quote
Old 02-26-2008, 01:59 PM   #5
Car: 06 WRB STI
Fav Mod: getting out of the army
Id like to know this also as I am having pretty much the same problem. When I take off, from a dead stop going all the way left, the car reacts voliently and I have to give a lot of gas to prevent stalling.
Unclejesus is offline   Reply With Quote
Old 03-18-2008, 05:30 AM   #6
Car: Silver 05 STi
Fav Mod: Stage 2
bump..
sounds similar to me
Misanthrope789 is offline   Reply With Quote
Old 03-18-2008, 09:37 AM   #7
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
Replace and properly torque your axle nuts. There's a thread around here about it. Sounds like what you're hearing.
Old 06-02-2008, 12:54 PM   #8
i had the same problem its the left front axle that has gone bad
stijon is offline   Reply With Quote
Old 06-05-2008, 01:11 PM   #9
seems like its not the axle after all the dealer can't find the problem
Old 06-06-2008, 07:06 AM   #10
Car: black 07 wrx sti
same here only happens once in a while though.
gloc8_13 is offline   Reply With Quote
Old 07-04-2008, 06:46 PM   #11
I didn't realize this thread had gone active again recently. For anybody reading it, here is the conclusion (for my problem, at least): the axle nut was not properly torqued from the factory. This happened on the left side at about 25K miles (when I first made this thread). It happened to the right side as well later at 36K miles. Both fixed under warranty, neither has recurred since (up to 48K miles now). Worth noting is that according to the dealer, the left side nut had actually backed off a fraction of a turn (despite the lock), but the right side was still locked in the original position.
It's not a very common issue, and at the time of the second one happening to me I couldn't find another example where it had occurred to both rear axles on a single car.
Old 07-04-2008, 08:24 PM   #12
Non-Reformed Meth Addict
Car: '06 WRB
I'm currently having the same issue and have read about the axle nut torque problems. Does this require new nuts or just a retorque with new reatiners?
Old 08-20-2008, 08:33 PM   #13
Car: obp 05 sti
Fav Mod: pre paid legal
for posterity,
you have to replace the axle nuts. the "retainer" and nut are one part, the same part.
i did the rear tonight, worked like a charm.
resonant_evil is offline   Reply With Quote
Old 08-21-2008, 07:12 PM   #14
Car: 05 STi CGM Stg2
I have been saying this a lot but the sound sounds like axle nut or rear endlink. rear endlinks r easy to check so do that first.
Old 08-22-2008, 06:58 AM   #15
Black Dragon STI
see post #11
