Old 01-26-2007, 10:22 PM   #1
Car: 06 Subaru STI
Fav Mod: DomTune
IWSTI Addict since: Mar 2006
Default clutch engagment
whats up guys well for the past few weeks i have been noticed that my clutch engagement is alot different than it was 2k miles ago it engages when the clutch pedal is about 1/2 the way out, usually it would engage right away like a quarter of the way up any ideas to adjust it or fix it? can i?
ArizonaSTI is offline   Reply With Quote
Old 01-30-2007, 09:18 AM   #2
Car: 08 WRX STI
IWSTI Addict since: Aug 2006
I've noticed it too, at 6,400 miles now. Used to engage close to the floor, once it warms up it engagement is all the way out.
Chuckl is offline   Reply With Quote
Old 01-30-2007, 11:42 AM   #3
Car: 03 Ford Mustang GT
Fav Mod: Selling the GT for an SWP '07 STi
IWSTI Addict since: Jan 2007
It is most likely some kind of cable stretch. At least I had that problem in mustangs. I am not sure if the STi clutch is cable or hydraulic.
Most likely it is a simple adjustment to the clutch system. It takes me 5 minutes to tweak in my clutch.
STi Mark is offline   Reply With Quote
Old 04-12-2007, 12:15 PM   #4
Car: 05 Subaru WRX STi
Fav Mod: Pioneer D3
IWSTI Addict since: Mar 2007
Can u explain how? I have the same clutch issue.
thanks.
AGUSTA is offline   Reply With Quote
Old 04-12-2007, 03:51 PM   #5
Car: 2006 Corvette Z-51
Fav Mod: Buying a new car.
Send a message via ICQ to PowerLabs Send a message via AIM to PowerLabs Send a message via MSN to PowerLabs Send a message via Yahoo to PowerLabs
Very unlikely considering that the STI clutch is hydraulic.
Look at your pedal box; the clutch linkage IS adjustable but you may get clutch slip by adjusting it too far because the clutch will always be depressed a bit. My guess is the OPs clutch is wearing thin because of agressive driving. There isn't much you can do to "fix" it once it wears down.
PowerLabs is offline   Reply With Quote
Old 04-15-2007, 09:49 AM   #6
Car: 04 JBP WRX STi
Fav Mod: ProTune by Hill at Agile
IWSTI Addict since: Mar 2004
I think your clutch is just wearing. I have 33,000 miles on my OEM clutch with plenty of spirited miles and some launches. My engagement is as far to the top as physically possible. I am just waiting for it to start slipping.
It is a hydraulic clutch...
Sti491 is offline   Reply With Quote
Old 05-02-2007, 07:24 PM   #7
Car: 05 Subaru WRX STI Wh
Fav Mod: Invidia N1 catback, Helix DP
IWSTI Addict since: Jul 2005
Default Re: clutch engagment
I just had my new clutch installed and I have not exceeded 4k rpm's since the install. (break in purposes) However during break in my clutch engages at the very top. So given that I know my clutch isnt going bad is it just a matter of adjusting? And how do I go about that? Thanks
speedjunkie is offline   Reply With Quote
Old 05-02-2007, 08:36 PM   #8
Iron Fisted
Car: '05 STi
Fav Mod: Sparco seat
IWSTI Addict since: Sep 2006
What do people think about a clutch delay valve delete in a case like this? Would it help??
Old 05-02-2007, 11:12 PM   #9
Car: 06 OBP STi
IWSTI Addict since: Sep 2005
Wow...almost 7k on the ODO on my 06 with the same issues...it engages 1/2 way up now whereas before it was 1/4. It seems to be normal though... BTW anyone notice noise when depressing the clutch? I can hear the slight VERY Slight linkage noise when I depress and let the clutch out. Is this normal? I know the STi makes plenty of noises so I'm not worried too much just wondering if anyone else has this...???
-Ryan
r12rex is offline   Reply With Quote
Old 05-03-2007, 04:46 AM   #10
Car: 07 Subaru WRX STi
Fav Mod: Cobb AP v2
IWSTI Addict since: Dec 2005
-Ryan
Same here on my 07 and I only have about 1k miles
chaleexd is offline   Reply With Quote
Old 05-03-2007, 08:09 AM   #11
Car: 02 WRX faux STi
Fav Mod: roof rack
IWSTI Addict since: Apr 2003
you could look into flushing the clutch cylinders,
the master and the slave with new fluid.
it wouldn't hurt..
jaxscuby is offline   Reply With Quote
Old 05-03-2007, 08:43 AM   #12
it wouldn't hurt..
I had this done when the clutch was installed. So there is no way of adjusting the engagement that anyone knows about?
Old 05-03-2007, 09:55 AM   #13
Yeah, look underneath your gas pedal; there is a lever arm there that can be adjusted. If you mess with it though you might have an effect similar to resting your foot on the clutch pedal all the time; I.E. it never fully engages so it will tend to slip.
I wouldn't mess with it unless I was sure that the problem was with the engagement itself as opposed to the clutch wearing thin.
