Old 01-22-2007, 05:28 AM   #1
Fav Mod: TBE
IWSTI Addict since: Sep 2006
Default DCCD drive ratios
I've been searching for a while and I still can't find the info I'm looking for. All I want to know is what is the drive ratio for each arrow on the DCCD? Like the green notch on the bottom is 40F/60R or whatever it might be. Sorry if this has already been discussed but I can't seem to find anything. Also, I did read the DCCD Primer part 1 in the stickies...
Old 01-22-2007, 05:53 AM   #2
Car: '04.5 STi
IWSTI Addict since: Apr 2006
Read it again.
Basically, that little adjustment knob isn't there to change the front/rear ratio. For your '04 it's 35f/65r when the differential is OPEN. When the differential is locked, the torque split can really be anything depending on available traction.
What the knob does is adjust the degree to which the two axles connected to the center diff can spin at different speeds.
