| | #31 | |
| Authorized Vendor | Quote:
| | #33 | |
Edit: Just checked. I'm up to 700 miles on it. Last edited by Turninconcepts.com; 01-31-2007 at 01:14 PM. | |
| | #35 | |
| Senior STI Driver Car: 05 STi WRB Fav Mod: Protune Location: western burb, IL Posts: 376
IWSTI Addict since: Oct 2005 Trader Rating: (0) | Quote:
this is by far one of the best write-ups i've ever seen on iwsti forum. on the write-up alone, i am compelled to order motul 300. one quick question, where can i buy motul 300, and how much quantity do i need to order? i haven't hit 30k yet (24.4k miles on '05), so come 30k mile service time, i want to be fully prepared. | |
| | #36 | |
They come in 1 liter bottles. You're car takes JUST over 4 liters (which is a PITA) so you'll need 5 bottles. Best bet is if you have buddy that way you can split that last bottle and not waste so much. | |
| | #37 | |
| Senior STI Driver Fav Mod: Agile protune Location: vahbeach Posts: 394
IWSTI Addict since: Dec 2005 Trader Rating: (0) | Quote:
| | #38 |
| Amateur STI Driver Car: Aspen White 04 STi Location: SoCal 626 Posts: 29
IWSTI Addict since: Mar 2006 Trader Rating: (0) | Great thread, and I am picking up my 04 STi from the dealer tomorrow morning, I had the same 4th gear grinds that you had talked about, and it didn't start happening until after I had changed my gear oil to Redline gear oil, I can't remember now which one it was, but I had got it from Option here in Irwindale, but I seriously thought it was my synchros all along, and the dealer told me that after replacing the gear oil with the "factory recommended" gear oil, that it's smooth as butter, per his exact words hehe...but I will be sure to ask him tomorrow what that exact "factory recommended" oil is. I hope my synchro's won't go bad, because my car is 400 miles away from 60k, which means no more warranty! I'll post up what they did, just for some added info for you guys. Subscribing also. |
| | #39 |
| The Next Petter Solberg Car: 200? WRX STI Fav Mod: Super EX/RM-01A Location: NYC Posts: 939
IWSTI Addict since: Nov 2005 Trader Rating: (2) | hmmm interesting, always love to read your articles...i am currently runing Valvoline 75w90 (white bottle from autozone) and is working fine....but maybe this valvoline is causing the clunking in my tranny in tight u-turns even when i have the DCCD set to AUTO mode... |
| | #40 |
| Spec C Club Car: 06 Subaru WRX STi Fav Mod: My right foot... Location: Waterford CT Posts: 1,989
IWSTI Addict since: Nov 2004 Trader Rating: (1) | So, it looks like that the best oil for our trannies are the Motul 300 or Valvoline 75w90 (stock oil, right?). What is the Subaru Extra-S? How often the tranny oil should be changed? PS: People, these oils are for the tranny NOT for the rear differential. For the rear diff. you need the special LSD oil. Looks like the best one is the stocker from Subaru. Good job Clint! Thanks. By the way, I really enjoy your sway bars. |
| | #41 |
| GT R US
Car: CUTN EDG project Fav Mod: $20. mudflaps from auto zone Location: my cave Posts: 5,967
IWSTI Addict since: Dec 2003 Trader Rating: (1) | motul makes an even higher quality gear oil - gear comp (formerly ff competition) at about $23.-25. a liter. i've been using it for a while and love it but you have to be nutz enough to hack the price. i also had good luck with the gear 300 so i'd try that first if youre put off by the cost. |
| | #43 |
| Grassroots STI Racer Car: 06 STI - SGM Fav Mod: HPDE Location: Long Island, NY Posts: 570
IWSTI Addict since: Dec 2004 Trader Rating: (1) | Good post. I'm a little baffled though at the absent Redline or RoyalPurple offerings. I did see one Redline issue with an issue...let me guess...you used the one without friction modifier???? I've never used Motul fluids, except the RB600 brake fluid, as the company is French...there's other choices out there. In prior vehicles, I experimented with the different synthetic fluid companies. For example, and for illustrative issues I'll just pick Royal Purple for now (as that is the fluids I use now). I initially installed the RP gear oil in a mid-engine car's tranny. I had horrible grinding and very reluctant synchros. I went to my speed shop and asked if they had heard of this issue.... They asked which one I used and guessed correctly that I didn't use the one with the added friction modifiers. The friction modifiers allow the synchros to match speed better...the non-modifier fluid is too slick, and is really only used for non-synchro use. -I switched to the friction modifier fluid and all was fixed. It really felt great, very smooth. Since that happened, many years ago, I've heard of many people having funky experiences with Redline and RoyalPurple gear fluids....always this has been the result of using the WRONG fluid. There's good news, though. Should you find that your new fluid is causing grinding or reluctant synchros, Redline sells their friction modifier in a small bottle. You add that to your case. Same thing as their "modified" fluid. And any cars exposed to the roadcourse may want to consider the higher grade fluids. Amazing temperatures seen by trannys during those 20-30 minute sessions. Be good, TomK Copied from Redline's website... Red Line Oil's MTL and MT-90 are designed to provide excellent protection and improved shiftability for manual transmissions and transaxles, having cured the problem of hard shifting in thousands of transmissions with shifting troubles. How? They have the appropriate coefficient of friction for most manual transmission synchronizers (many gear oils, engine oils, and ATFs are too slippery for proper synchro engagement). And, the wide viscosity of MTL and MT-90 allow proper shifting over the entire temperature range which the transmission will experience. The synthetic base oils used have a very high viscosity index which provides relatively constant viscosity as temperature changes. MTL is a low 70W at very low temperatures and a high 80W, nearly an 85W, at elevated temperatures, providing adequate viscosity to prevent wear and deaden gear noise. MT-90 is a thicker 75W90 version of MTL. The shear stability and oxidation stability of these products are excellent, thus the physical characteristics of Red Line MTL and MT-90 will change little with use. Last edited by ace996; 02-18-2007 at 10:26 AM. |
| | #44 |
| STI Driver | i've had good experience with reline in both my 300zxtt and my '98 jdm integra.. got rid of 3rd gear grinds. not sure about subys though.. think ima try this motul300 stuff. we'll see what happens.... |
| | #45 |
IWSTI Addict since: Nov 2004 Trader Rating: (1) | If I remember correctly some members here didn't have good luck with Red Line tranny oil in their STi. This ad is not endorsed by this member. Please register or login to hide this ad. |
