Old 01-16-2007, 01:56 PM   #16
jph
Originally Posted by wdb
Those sound like my symptoms; no grinds, but tough shifting when cold + occasional balkiness into 1st. Can you tell us how long you have been using Motul Gear 300? Time and mileage would both be useful.
changed to motul gear 300 at 45k miles
i'm at 56k miles now.
J.
jph is online now   Reply With Quote
Old 01-16-2007, 05:17 PM   #17
Fav Mod: TiC AST's - 7/6K
I have been using Motul 300 for 30K miles. 50K on the tranny total. Great stuff. Sometimes it is slow to shift into 6th while warming up, but it did that with the stock fluid too. Clint, if you descide to sell Motul, I'd gladly buy some from you.
Old 01-16-2007, 06:32 PM   #18
Muller Chevrolet
Fav Mod: a new 08 STi
after my clutch swap, i put in some mobil we use in toyota's at the dealer..we get it in big barrels.
i think it was synthetic, but seems to hold up nicely...but time will tell.
Old 01-17-2007, 05:32 AM   #19
Moderator & ECU Tech
Fav Mod: mo boostaz
I've been using Motul Gear 300 for ~8000 miles. No issues. Works great.
Clint, if you can, please explain how *you* removed the pan on the tranny. That thing (at least to me) seems like it is installed with SuperGlue. I gave it a tiny try when I swapped my fluid at 15K but it seemed too glued on and I didn't want to damage the mating surface with a screwdriver or putty knife. However, I am resigned to do this when I swap the fluid again at 30K (only 7K more miles). I know I can get it off - that isn't the issue. I want to know how *you* got it off because I don't want to use the screwdriver/putty knife if there is a better way. Also, I am a little worried about cracking the pan by prying on it that hard.
t
Old 01-17-2007, 06:09 AM   #20
Trader Rating: (50)
t
I was wondering when this question was going to come up. I used a razor blade. find the seam between the two at a corner. At the corner tap the razor blade in using a small hammer. Once it's half way in grab the razor and pull down.
Old 01-17-2007, 06:28 AM   #21
Car: 05 STi CGM
Fav Mod: whiskey tango
Is there a filter that needs to be changed when you remove the tranny pan or is it a filter element that you can clean? Is there a sealing material that you need to apply when putting the pan back on or is there a gasket, if so is liquid gasket ok or is there a higher temp adhesive that is specified to be used. Oops i guess i should read....is RTV what you used? What are the torque specs for the bolts?
Old 01-17-2007, 07:14 AM   #22
Trader Rating: (50)
torque spec is really low on those - 4.7lbs. RTV is what is used.
Old 01-18-2007, 06:45 PM   #23
Car: 06 cgm sti w/ppg dog
Fav Mod: RIP 04 psm sti
Send a message via AIM to nhsilversti Send a message via Yahoo to nhsilversti
from my experiance, dont use the 75-140 version of this oil. long story but the short of it is, i now gring into 6th. started happening an hour or so after it was put in there.
ted
nhsilversti is offline   Reply With Quote
Old 01-20-2007, 08:35 PM   #24
Teh Other White Meat
Trader Rating: (22)
subscribed
Old 01-27-2007, 12:24 PM   #25
Holy smokes, that stuff is expensive. I wasn't planning on $100 to change the transmission fluid. But I guess if it's the best...
Edit: Phew, found a place cheaper. First place wanted $23.50/liter. Youch.
Old 01-27-2007, 04:30 PM   #26
Car: 05 crystal grey sti
guess i'll never understand why people find the place with the good price and don't SHARE . uumm link please ?
kursplat is offline   Reply With Quote
Old 01-28-2007, 09:29 AM   #27
Fav Mod: EQ Tuning
ahhhh good ole Motul gear300! I've been using it for 20k now and no tranny issues at all.
BM_STi is online now   Reply With Quote
Old 01-28-2007, 10:03 AM   #28
Trader Rating: (22)
$13.50/liter
Old 01-29-2007, 08:17 AM   #29
Originally Posted by snorky
thanks
Old 01-30-2007, 09:46 PM   #30
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
Trader Rating: (21)
Send a message via AIM to AndrewSS
Good read, I have already done 2 flushes myself and the dealer did my last one (all by 16k miles!!! dont ask, long story)... and they put 75w80 valvoline in it... they overfilled it pretty bad and the trans SUCKS big time in the cold... until its warm its horrible to shift...
I am probably going to flush it out for something better... maybe this motul 300 stuff or proper valvoline (75w90), OR that "Subaru Extra-S"
Dont worry, my rear diff has the good subaru LSD stuff.
AndrewSS is offline   Reply With Quote
