Old 05-06-2008, 11:52 AM   #196
Car: WRB 04.5 WRX STi
IWSTI Addict since: May 2003
Send a message via AIM to red5001
Default Re: Clint's findings on 6MT tranny fluid
Originally Posted by Turninconcepts.com View Post
Yourself.
There's two places that work on the TiC cars. TiC and P&L.
I went to the local dealer the other day to get the two crush washers for the TWO drain plugs on the tranny. The parts guy and mechanic looked at me funny that I asked for both drain plugs. come to find out the dealr only has only ever pulled the one plug(the large one) according to there computer they have never stocked the small of the two crush washers. I know when I drained my tranny a good bit came out of the lower one after the larger one was removed. That is why I do eveything my self.
red5001 is offline   Reply With Quote
Old 05-06-2008, 12:46 PM   #197
Fav Mod: Driving School / Trunk swap (no attention ftw)
IWSTI Addict since: Sep 2006
f'ing ridiculous...i hate the dealership. with a passion
mgsm666 is offline   Reply With Quote
Old 05-06-2008, 12:58 PM   #198
Fav Mod: TiC AST Coilovers!!!
IWSTI Addict since: Nov 2005
Trader Rating: (92)
hmm, my shifter is quite a bit stiffer to shift than my brothers with the original fluid still in it. This may be attributed to the Motul fluid, but I can't say because it was just installed so i have nothing ever to compare it to
WC LATHE WERKS is offline   Reply With Quote
Old 05-06-2008, 01:35 PM   #199
The next Sebastien Loeb
Fav Mod: Super Low Friction Brake Pads
IWSTI Addict since: Apr 2006
Trader Rating: (24)
could be the effects of mileage. bolts loosen, bushings degrade, etc.
Old 05-06-2008, 01:52 PM   #200
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
Loosen the pivot bushing. Make sure there is grease on the faces. tighten to feel.
Old 05-09-2008, 09:13 AM   #201
Car: 08 Subaru STI
IWSTI Addict since: Dec 2007
I've been following this thread with interest because my new 08 STI grinds sporadically shifting from 3rd to 4th. Has a little over 800 miles now; started at about 500, but only once or twice a day. Can't make it happen. (I started a thread on this -- New 08 STI: Occasional 4th Gear Grind... -- but it didn't generate much interest.)
Subaru customer support opened a case number for me, and I took the car into the dealer yesterday. Although (not surprisingly) they couldn't duplicate the problem (neither can I; it just happens every now and then), they were familiar with it, having had something at least similar on another 08 STI they sold and also had heard of it otherwise. They had apparently fixed the earlier one by replacing the gear oil with what described as a special Subaru oil. I was so sure that this was going to be the Extra-S that's been discussed here that I didn't nail it down, but in the event what they added was what seems to be yet another Subaru oil:
SOA635011 Transaxl Lub Non Jus
Does anyone know what this is? Is a "Transaxl Lub" a gear oil at all? By the way, can't recall if someone has provided this, but if not and if anyone is interested, the Subaru part no. for the 75W-90 Extra-S is K0322AA093.
Anyway, I picked up the car at closing time and, wouldn't you know it?, had one of my daily 3rd-4th grinds on the way home last night. On the other hand I haven't had any since then, and I've shifted from 3rd to 4th 45 times today (yes, I'm counting!).
I guess I'll wait to see if the grind returns. If it does I'll take it back and see if they'll add the Extra-S. Subaru covered the cost of the first replacement, and I hope and assume they'll cover it if the "Transaxl Lub" is not Extra-S and it has to be added.
Any thoughts?
Crozetian is offline   Reply With Quote
Old 05-09-2008, 12:08 PM   #202
Car: 08 Subaru STI
P.S. According to the service tech at my dealer who I just checked with, the stuff they put in -- SOA635011 Transaxl Lub Non Jus -- is Extra-S, maybe in a different container or something else different enough to have a different part number. Knock on wood, I haven't had a grind today yet, so maybe it'll work....
Old 05-14-2008, 06:47 AM   #203
Fav Mod: The Stealthy Winglessness!
Send a message via AIM to Blinden
Just placed an order with TiC for some Gear Oil, hope to get rid of some high gear grind before I go full on to syncro replacement.
Blinden is offline   Reply With Quote
Old 05-14-2008, 07:51 AM   #204
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
IWSTI Addict since: Jan 2005
I'm not sure if I would trust a dealership mechanic's word. Did the fluid smell like regular gear oil, or heavy-duty Pine-Sol? If it smelled more like Pine-Sol, it's probably Extra-S. If more like regular gear oil (decaying dinosaur flesh) then it definately wasn't. I'm not sure why the XS smells different, but it was rather surprising when we opened the can.
Draco-REX is online now   Reply With Quote
Old 05-14-2008, 08:38 AM   #205
Car: 05 subaru WRX STi
Fav Mod: Full-Race FTW!
IWSTI Addict since: Aug 2005
Send a message via AIM to jnorth85 Send a message via MSN to jnorth85
here is a great thread to read over on the nastisock.
Bartender: One Scotty's ****tail please. - NASIOC
the USC is not good for the trans but toward the end of the post there is some great discussion on different flids and how they effect the trans.
IIRC Andrew tech and DS1 both rebuild lots of tranny's and both reccomend the motul gear 300 or Valvoline Syn 75w90
i have been running the 75w90 in the swapped GC and have no complaints. however i have only driven it for a few hundred miles.
jnorth85 is offline   Reply With Quote
Old 05-14-2008, 09:04 AM   #206
Car: CGM 05
Fav Mod: IAG 38mm EWG
IWSTI Addict since: Mar 2008
Send a message via AIM to 1loudsti
seems to be just discussing the 5mt though....this is getting sorta crazy im just gunna save up and put a damn ppg doggy in it and be done!!!!! gah
1loudsti is online now   Reply With Quote
Old 05-14-2008, 09:14 AM   #207
if you get toward the end there is a lot of discussion about the 6MT
Old 05-14-2008, 09:48 AM   #208
Car: CGM 05
like what page? i got frustrated and skipped to the end and couldnt find anything lol
Old 05-14-2008, 10:55 AM   #209
start at around post 1100-1120ish.
Old 06-02-2008, 01:30 PM   #210
no dice for me it seems, still grinding with the motul, any last ditch additives to throw a quart or so of in?
It actually seems as though 5th may have gotten a bit better, but 6th still grinding.
