| | #181 | |
| Authorized Vendor | Quote:
There's two places that work on the TiC cars. TiC and P&L. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #183 |
| Lurker Car: Urban Grey 2007 STi Fav Mod: Coming Soon Location: Fayeteville, AR Posts: 3
IWSTI Addict since: Jan 2008 Trader Rating: (0) | I tried to go to Motul's web site to look at their oil selection and it seems they are more interested in flash websites than selling oil. None-the-less I was unable to get any info nor was North America or the US an option to select. Thanks for all the great info - I am at 3900 miles and I am going to go with the Gear 300. As for the rear diff, someone above mentioned using the Motul Gear FF instead of the PA-90 because it met the correct specifications. Does anyone have any information on this? |
| | #184 |
| Black Dragon STI Car: 07 OBP STi 03WRB WRX Fav Mod: My whole suspension Location: Columbus, OH Posts: 1,782
IWSTI Addict since: Jan 2005 Trader Rating: (0) | Got a can of this in my garage: ![]() Can't wait to put it into both my cars. A friend of mine has already used some and he's very happy with it. |
| | #185 |
| STI Driver
Car: 07 WRX STi Fav Mod: Tires and Brakes! Location: AZ Posts: 201
IWSTI Addict since: Dec 2005 Trader Rating: (1) | just changed my oil w/ gear300! Seems to shift a lot smoother and a smidge easier to get into reverse. The real challenge will be track day this weekend! Also did rear differential with pa90 Am I the only one who likes the smell of gear oil |
| | #186 |
| Spec C Club
Car: Blue 05 STI Fav Mod: 4th gear wheelspin Location: Upstate NY Posts: 2,096
IWSTI Addict since: Nov 2004 Trader Rating: (0) | |
| | #187 |
| Professional STI Racer
Car: 05 WRB STi Fav Mod: TiC AST's - 7/6K Location: Chesapeake, VA Posts: 629
IWSTI Addict since: Feb 2005 Trader Rating: (3) | |
| | #188 |
| Authorized Vendor | I can't stand it. I walked into the shop this this past Tuesday after doing a trans and diff fluid change on Saturday and trans removal on Monday and could smell nothing but gear oil. I almost turned around and went home. Tony |
| | #189 |
| Junior STI Driver | |
| | #190 |
| Junior STI Driver | I swapped out to the Motul 300V today from Amsoil SVG. I'll give a report after I get some driving under my belt about the two. I did a complete swap on both dropped the pan and cleaned the magnet under-neath. It should be interesting. |
| | #191 |
| Silver Member | let us know...i know me for sure! im running SVG right now and i still get a small grind shifting hard into 5th..i dont know if you have the same problem or not but if you do (did) please let me know if the fluid swap cures it! |
| | #192 |
| STI Driver
IWSTI Addict since: Dec 2005 Trader Rating: (1) | Just got done with track yesterday. Gear 300 is awesome. Smoother crisp shifts/down shifts, all the way compared to stock fluid |
| | #193 |
| Junior STI Driver | Got probably 60 miles today on the Gear 300 vs the SVG. The SVG had 15-20k on it, I gotta say that the gear 300 does seem better. This could be impart to the fresh fluid. On my 04 Transmission, I have zero grinds, 80,800 miles and its been babied just about all of them. I also have the kartboy SS with all bushings down. 1st to 2nd was previously "knotchy" is the best way to describe it, its less knotchy, third to sixth are as smooth if not more then before. Reverse does engage easier. I think 300 Gear is as far as you can take a 75w90 GL5 oil for our cars at present time. If the fluid stays this good, I will continue to use the motul in place of the SVG from amsoil. |
| | #194 |
| Authorized Vendor
Car: 04WRX /STi Swap Fav Mod: TiC AST Coilovers!!! Location: Tri-State, USA Posts: 1,332
IWSTI Addict since: Nov 2005 Trader Rating: (92) | Just got a 6speed on my WRX. Drove around 200 miles on it since sunday, and I'm using the Motul 300 fluid in the box and the r.diff. It works well for me, no grinding, and pretty good shifting all the time. |
| | #195 |
| Junior STI Driver | I switched to the 300 a couple weeks ago. If anything its slightly harder to get everything into gear. Everything feels stiffer. Didnt help me get into first easier in the mornings like id hope aswell. Gota say not horribly impressed. Think ill try Extra S next time. This ad is not endorsed by this member. Please register or login to hide this ad. |
