Old 03-04-2008, 11:32 AM   #166
Car: 05 WRB STI
IWSTI Addict since: Nov 2007
Send a message via AIM to bdpakaknox Send a message via Skype™ to bdpakaknox
Default Re: Clint's findings on 6MT tranny fluid
I wonder why changing the fluid in the sti tranny, with 75w90 valvoline that was already in it causes so many issues?
Or do all sti's use the S fluid? I called a local dealership and they said it was just normal bone oil.
bdpakaknox is offline   Reply With Quote
Old 03-04-2008, 09:34 PM   #167
Moderator Elite
Car: 04 Subaru WRX STi, W
Fav Mod: KartBoy SS & Bushings
IWSTI Addict since: Jan 2001
Send a message via AIM to MKIVSupra Send a message via Yahoo to MKIVSupra Send a message via Skype™ to MKIVSupra
Well I just switched to Motul 300 in the trans and what a difference. I drained out the Amsoil I had in there for only 4k miles. Before that I had Valvoline dino for 20k miles with no issues and figured I would try Amsoil since I like their engine oil and after I read some good reviews of it. Well right after I put Amsoil in I had a 4th gear grind and an occasional 5th gear grind and it did not like to downshift to 2nd gear. I put Motul 300 in and what a huge difference. No more grinds in any gear and downshifting is like butter.
MKIVSupra is offline   Reply With Quote
Old 03-05-2008, 10:19 AM   #168
Car: '04.5 STi
IWSTI Addict since: Apr 2006
Still using OEM... still shifts like new.
Old 03-05-2008, 11:07 AM   #169
The Godfather of Meth
Fav Mod: Every single one!
IWSTI Addict since: Jun 2005
Trader Rating: (30)
Take OEM fluid to the track and see how "smooth" it will be after a few sessions in the summer. Hence the reason why I switched. I just need something more hardcore than the Amsoil. Motul is what I am going to use now!
Chris05STi is online now   Reply With Quote
Old 03-05-2008, 11:17 AM   #170
Car: '04.5 STi
I have been there and done that. In fact, I'm still running the same fluid I ran last Summer when I did a track day on a 115 degree day here in Alabama. Before I changed the fluid that the car came with from the factory I had many, many autocrosses and a few track days on it and it still felt fine, just a tad stiff after three years and some hard use.
If you enjoy running your car really hard on extremely hot days you may wish to consider hooking a fluid cooler up to your gearbox. If you're actually cooking the OEM fluid I'm sure you'll cook the Motul as well, and I'm not entirely convinced that you actually cooked the Amsoil. It may have not played well with the gearbox in the first place.
Old 03-07-2008, 12:19 PM   #171
Car: 2003 WRX
IWSTI Addict since: Mar 2008
Hi Everyone
Great forum, I was really looking for that sort of information.
After the last visit to the dealer (tranny fluid changed), ALL the gears started grinding after the engine/tranny get hot (like 20 min in bumper to bumper traffic). When engaging first gear, it would sometimes kick the shift lever back to neutral real bad.
Went to the dealer twice - first time they tricked me into changing the clutch (i'm usually not THAT stupid, but well, sh%t happens, I guess I wasn't thinking that day ), took it out of the dealer - same ol same ol. Then I drove it back to the dealer a few months later (I live in NYC, finding time to do anything at all is really not easy), and insisted on having the tranny fluid changed.
They found that the level was low, changed the fluid - well, it is better now, I agree, BUT, when really hot, it starts all over again.
Now I would wonder how did they manage to put a low level of low quality oil twice (the problems started after the first tranny fluid change), and to do the same thing after refilling the tranny after the clutch change.
In short - does this oil discussion apply to 6MT trannies only ? Mine is a regular 2002 WRX 5MT. Or will my tranny work with the same oil as the 6MT ?
Thanks in advance
goblin is offline   Reply With Quote
Old 03-07-2008, 02:14 PM   #172
Car: 2006 WRX Wagon 6 Spd
Fav Mod: Chateau Montelana 2000 Cabernet Sauvignon
IWSTI Addict since: Oct 2006
Just read all 18 pages. Very good stuff. Also just ordered 5 quarts of 300 from TIC. Thanks to all for the advice and comments.
Schell is offline   Reply With Quote
Old 03-07-2008, 04:32 PM   #173
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
Originally Posted by goblin View Post
Hi Everyone
Thanks in advance
If you have the rear spline plug (otherwise known as the butt plug, and I am not making this up) then you don't need to drain the tranny when you drop it.
Turninconcepts.com is online now   Reply With Quote
Old 03-07-2008, 05:19 PM   #174
Car: 2003 WRX
Thanks !
That would mean that they didn't even touch the tranny fluid when they changed the clutch. Then the guy looked me in the eye and said "yes of course, we changed it". Really professional...
I guess my next question is who can I trust to service my car in the future (NY-Queens area)
Old 03-12-2008, 11:25 AM   #175
STI PILOT
Fav Mod: MY GARAGE PERIOD
IWSTI Addict since: Nov 2003
i used the motul in my 00 2.5rs with 115k miles. put it in around 105k and you really could tell the difference. car shift smooth. also did the rear diff. will be doing the same to the wrx and the sti when its time to switch em out.
+1 for motul... good s**t!!!!
Novtec1 is offline   Reply With Quote
Old 03-12-2008, 11:37 AM   #176
Fav Mod: wingless and mis-fires
Send a message via Yahoo to toogood
very good info to know
toogood is offline   Reply With Quote
Old 03-19-2008, 02:07 AM   #177
Car: Blue 06 S204
IWSTI Addict since: Sep 2007
2 years old and only 5,625 miles clocked.
Im using Motul Gear300 for the tranny, resolved a 3rd gear mild grind issue prior to oil change.
For the rear diff: I would suggest you guys take a look at using Motul Gear FF-LSD Type 2 rather than the PA90, specs suggest a multigrade LSD oil and Gear FF meets the requirements.
innobrand is offline   Reply With Quote
Old 03-19-2008, 02:57 PM   #178
Car: 05 STi OBP
Fav Mod: Data Acq System
IWSTI Addict since: Jul 2006
I have changed the stock fluid at 30k to the Valvoline cheap stuff and have had no issues tracking or DD my car. I put 60k on my ride now. However, the STi tranny does feel hard to shift since I bought this car, no different. I don't hear no grinding but maybe that is because my radio is always up to hide the 50 other rattles. At the track I never had issues. For the diff I use the stock Subby stuff and I guess its working fine. No complaints here.
MGizzle is offline   Reply With Quote
Old 04-12-2008, 05:01 PM   #179
IWSTI Addict since: Jul 2007
Hey,
Guys I have and 06 STI and I changed the tranny (w/ Motul Gear300) & diff fluid @ 26k since like at 25k my 2nd began (when I was racing it) to grind and sometimes downshifting to 5th was not easy. Now shifting, downshifting everything feels like butter but sometimes my 2nd still grinds when I shift at like 6,100 RPM.
Any advice? Or recomendation? Maybe the syncro is a bit hurt?
Thanks,
D
D_STI is offline   Reply With Quote
Old 04-12-2008, 05:05 PM   #180
Car: WRB, 04, WRX STi
IWSTI Addict since: May 2006
Im running the SVG currently, my order of 300V is on the way. I'll give my honest review of both, the SVG has been in for roughly 15k.
You guys with grinding issues might want to try out some auto-rx....
Engmus is offline   Reply With Quote
