Old 01-15-2007, 09:08 PM   #1
Car: AW 05 WRX STi
Fav Mod: Recaro Racing Seats
IWSTI Addict since: Sep 2004
Send a message via AIM to JKonquer Send a message via MSN to JKonquer
Default shifter problem
i've had the kartboy ss kit for a while and it seems like it need new lube job or something... when i move the shifter left and right while its at neutral position, it would squeak. it does it sometimes and sometimes it goes away...
is this normal or am i just paranoid?
JKonquer is offline   Reply With Quote
Old 01-15-2007, 09:29 PM   #2
Car: 06 STi
IWSTI Addict since: Jun 2006
it's probably not the shifter if self, most likely it's the lockout cable rubbing against the shifter shaft. just make sure the zip tie for the cable and shaft is really tight and make sure the zip tie for the cable and the shifter stay below the car is also tight.
gte123v is offline   Reply With Quote
Old 01-16-2007, 12:56 AM   #3
Car: AW 05 WRX STi
im not saying when its moving. just in general, whether the car is on or off. its very squeaky for the shifter
Old 01-16-2007, 08:07 AM   #4
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
make sure you have some grease packed down in the cup that the ball of the shifter fits into.
Turninconcepts.com is online now   Reply With Quote
Old 01-16-2007, 08:21 PM   #5
Car: AW 05 WRX STi
which grease should i use again? would lithium grease work?
Old 01-16-2007, 08:30 PM   #6
Trader Rating: (54)
that'll work fine, but dry out over time. We use wheel bearing grease as we have a ton of it sitting around.
Old 01-17-2007, 12:16 AM   #7
Car: AW 05 WRX STi
cool thanks man....
is there any other parts that might cause the squeaking?
also do you know what kind of sound it make when reverse cable is hitting the driveshaft?
Old 01-22-2007, 09:53 AM   #8
Car: 06 STI
Fav Mod: Prodrive oval tip
IWSTI Addict since: Mar 2005
i don't know if mine's hitting the drive shaft but whenever I throttle in 4th gear, it makes noise... is this the sound of cable hitting the drive shaft? i accidently forgot to ziptie the cable to the stay rod
