Old 01-14-2007, 05:32 PM   #1
Car: 05 WRB WRX STi w/ St
Fav Mod: High Performance
IWSTI Addict since: Dec 2006
Default Power steering problem @ auto-x--looses assist...
I did a search & didn't see anything related to this.
This is my 2nd STi & I never had an issue like this on the other car.
In a tight slalom, the steering looses assist, and becomes extremely difficult--I mean nearly impossible to turn the wheel.
I have a very aggressive driving style & really saw @ the wheel to maintain momentum & this condition won't do...
Anyone else ever experience this issue? I have a feeling if I bring it to the dealer they'll say it's "just fine"
TIA people.
George B.
GTB/ZR-1 is offline   Reply With Quote
Old 01-14-2007, 05:39 PM   #2
Poor Speed Racer
Car: 96 328
IWSTI Addict since: Mar 2005
I've seen this posted by a LOT of people. Basicly you are overheating the powersteering on the car. Throw a cooler on there ($200-$500) and you should be fine.
I'd pick up an B&M cooler from summit racing.
Old 01-14-2007, 06:48 PM   #3
I did a search w/ no luck--guess I must not have used the right key words, anyways...
Another STi driver just made a post on the autocross forum & stated he had the same issue on 2 of his runs--never happened to him before either.
The course had some very tight slaloms in some sections, and I think this must have caused the issue. I think it'll be fine on tradtional courses.
Thx for the response
Old 01-15-2007, 06:32 AM   #4
Car: 05 STi - Black
Fav Mod: No Lien
IWSTI Addict since: Mar 2006
does the STI have some sort of "speed variable" power steering?
I ask this because my 98 Prelude was like this during autocross, because the Steering assist was RPM dependant, not vehicle speed dependant. So when you're buzzing around in 1st gear at high rpm, there was almost no power steering.
I'm wondering if this could be the case with the STi as well.
Old 01-15-2007, 07:28 AM   #5
Not that I know of.
I was in 2nd gear & the RPM through that very tight part of the course was relatively low. I did try it in 1st during a fun run, but it didn't help the steering issue.
Old 01-15-2007, 07:39 AM   #6
Car: 06 CGM STi
Fav Mod: brake dust generators
IWSTI Addict since: Jan 2006
Send a message via AIM to osbjmg
It looks like it is RPM dependent from the specs:
"Engine-speed-sensing quick-ratio variable power-assisted rack-and-pinion.
Turns lock-to-lock: 2.6"
From: http://www.subaru.com/shop/specifica...ry=PERFORMANCE
osbjmg is offline   Reply With Quote
Old 01-15-2007, 07:51 AM   #7
Car: 05 STi - Black
Fav Mod: No Lien
^^^there you go.
Exactly what I experienced with my prelude - especially on the tighter courses.
Old 01-15-2007, 09:13 PM   #8
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
IWSTI Addict since: Aug 2005
So it makes sense running high RPM in low gear equates relatively low speeds with high engine speeds and makes it hard to turn. Interesting.
Old 01-16-2007, 06:19 AM   #9
Car: 2005 STI
Fav Mod: Methanol
IWSTI Addict since: Feb 2005
I have this problem as well.
I have added 9" rims and 145 azenis. With the stock setup I got it a little, if it was really hot and I pushed the car hard in auto-x. But since adding so much more weight tothe steering, I get it a lot more. Like you say, by the end of a tough slslom, the power steering fails and it gets REALLY hard to steer.
I agree this it is the power steering fluid getting too hot. I have felt mine before, and you can't even touch the container. B&M cooler might help, I have just dealt with it.
Just know that you arent the only one it happens to.
xrocket21 is offline   Reply With Quote
Old 01-16-2007, 06:35 AM   #10
Car: '04.5 STi
IWSTI Addict since: Apr 2006
I started getting this problem and I bought some Redline synthetic power steering fluid. I haven't put it in yet because the problem hasn't come up in a while. My particular issue is that I was sawing away at the steering wheel entirely too much.
Old 01-16-2007, 01:56 PM   #11
Yes, I forgot to mention I'm running 8.5" rims w/ 245 615s in an unlimited street-tire class w/ our club, so I'm sure that contributed to the problem.
The slalom @ the end designed to slow people down before the finish (co-designed & approved by the club President--yours truly ) will go down in our club's 47 year history as one of the tightest ever
Thx for the help guys & I'll be doing a flush & refill w/ synthetic to help w/ the issue.
Old 01-17-2007, 06:14 AM   #12
Car: 2004.5 Subaru WRX ST
Fav Mod: 17x10s
IWSTI Addict since: Aug 2004
I had this problem occasionally while autocrossing, but had the P/S fluid boil over while hot lapping at MidOhio. I was able to find a vendor selling a JDM Ver. 7 power steering cooler that is 100% plug and play. It's way less than the B&M version. Flush the fluid with Redline also, and you shouldn't ever have any issues. Good luck.
loworbitSI is offline   Reply With Quote
Old 01-17-2007, 07:12 AM   #13
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
Better fluid and a cooler will help.
i believe King of Imports has those Spec C PS cooler loops.
Old 01-17-2007, 07:47 PM   #14
Great tip loworbit & Turnin, but I've been searching all over the net for an hour w/ no luck so far. They go between $75-100--if one can be found...
If someone comes across one, pls pm me! Thx
Old 01-18-2007, 12:42 PM   #15
Trader Rating: (54)
They really aren't all that special. you could build one with a small cooler core (even a cheap loop of copper with fins will work), some hose, and some aeroquip fittings. You can mount it behind a fog cover.
I've had an idea I've been sitting on for quite a while (like a year now) that would help this problem. The thing is to pull off this idea it would require a bunch of upfront $$ to even just build the prototype.
